How to install wings west lip on 94-97 integra?
Well I just got my lip back from the shop and I'm ready to install it. The question I have is. Do I keep the stock bottom lip, and put the wings west lip over it? Or do I remove the stock bottom lip? Thanks
You put the WW lip on top of the stock lower valence of the bumper. Check out http://www.wingswest.com and you can check out the installtion instructions there.
[Modified by PhAtBoY Si, 3:34 PM 4/5/2003]
I just got mine installed... it totally replaces ur stock lip, it should bolt right up!
yeah, i have the rs too w/o the vents. so i guess i'm gonna try to install it w/o the stock lip. What do I use, it doesn't look like i can use screws. How did you install it, did you use two-sided tape and what kind?
[Modified by Audio28, 7:50 PM 4/5/2003]
when you remove ur stock lip, there will be bolts that hold it up, and on the lip there will be a clip with thread for the bolt to screw in, I removed those clips and clamped it into my ww lip, then bolted it right on. I wish I had a picture to show you... maybe someone else can explain better..
the type I goes over the stock lip. the type II replaces.
