ITR Internals in a b18A
Old Apr 4, 2003 | 08:27 PM
JDMdaN.A's Avatar
Default ITR Internals in a b18A
What exactly has to be done to run full internals(crank rods pistons) if possible.
....im almost positive the pistons fit no problem for a nice mod but the rods dont. will the crank? and will the rods if i change the crank or will this not affect my stroke?
if only the pistons were done with basic cai/h/e chip AFC. would a decnt gain be
noticed?
?thnx
derek
[Modified by JDMdaN.A, 5:27 AM 4/5/2003]
Old Apr 4, 2003 | 11:18 PM
owen_the_soyboy's Avatar
Default Re: ITR Internals in a b18A (JDMdaN.A)
heres the catch....
when using itr rods, use an itr/gsr crank.
when using ls rods, use an ls crank.
otherwise you are all set.
if you use itr/b16 pistons on ls rods you get long stroke of ls crank and ls rods with the higher compression of the itr/b16 pistons... nice setup
Old Apr 5, 2003 | 04:26 AM
JDMdaN.A's Avatar
Default Re: ITR Internals in a b18A (owen_the_soyboy)
b ut is it better to run ls rods with itr pistons or itr erverything keep in mind my objective is to rev high! without vtec
dc4teg95
Jun 12, 2007 11:21 AM
vsmhatched
Aug 10, 2005 10:09 AM
allmtrdc4
Jun 3, 2004 04:05 PM
SoCaLNaTIvE
Jan 13, 2004 08:41 AM
drewlee
Jun 19, 2003 01:37 AM
