94-97 LS suspension Vs. 97-01 type R suspension
WHat the hell is the differance? I don't get it. Weren't the two cars made the same except with different spring rates and shocks? And if there are differances than they be corrected?
different wheels. ride height is lower, front upper strut bar, rear upper strut bar, trunk bar, rear lower tie bar (i think), .front sway bar and rear sway bar, maybe the alignment, brakes, and maybe some more.
I was looking to get some springs and shocks but they say their made for 97-01 type R's, can i put it on my car?
It's got a slightly different chassis, lots of reinforcements, rear lower tie bar, front strut bar, larger front and much larger rear sway bar, more negative camber in the front, about 3/4" lower, stiffer springs with same front and rear rates, performance shocks, trunk brace, and probably more that I don't remember.
Overall, that's just a small part of the picture. The R also has a better engine, better gear ratios, limited slip differential, large rear wing, front lip, no sidemoldings, no sunroof, no cruise control, less weight, 5-lug wheels, larger brakes, and plenty more. It's a track car out of the box.
There's nothing that an R can do that you can't modify an LS do, but it'll take plenty of $$$ to get it up to that level.
JAYBOOGIEZZ
May 10, 2007 10:29 AM
Rratedcivichatch
12
Aug 23, 2002 08:30 PM
mamaboy
Oct 26, 2001 04:01 PM
