wont pull
Old Apr 4, 2003 | 06:40 PM
DA6GSR's Avatar
Default wont pull
I just got an 88 hb with D15 and a 5 speed. The problem is when it isnt running you can put it into all 5 gears and everything is fine. If starts up fine and all. But when running and you release the clutch with it in gear it wont move. Would that be a clutch plate, pressure plate, flywheel, or axles?
thanks
Larry
92 GSR-broken
88 Civic DX hb-new toy
Old Apr 4, 2003 | 06:43 PM
crxY-49's Avatar
Default Re: wont pull (SloSpeedRacrGSR)
It most likely needs a new clutch
Old Apr 5, 2003 | 07:24 PM
Donkey85's Avatar
Default Re: wont pull (crxY-49)
a "ghetto" way to test to see if u need a new clutch is to put it in gear push the clutch in then let off the clutch, if it stalls then ur clutch is okay, if it keeps going then the clutch is no good
Old Apr 5, 2003 | 10:20 PM
markw's Avatar
Sounds like a broken cv joint. Check both your axles.
Old Apr 6, 2003 | 12:09 AM
Cvic90's Avatar
i broke an axle at the track couple weeks ago. my did you same other than i could change gears while running without touching the clutch.
Old Apr 6, 2003 | 03:53 AM
Mugen Dom's Avatar
more than likely the clutch is bad all u have ot do it check the cable first make sure its tight....then put it in gear with the ebrake all the way up put it in gear then try and start it with the clutch not depressed if the car moves its the clutch...btw the car will start its an 88 no safety switch
lopezchris21
25
Nov 19, 2023 08:24 PM
dexy
Jan 11, 2005 09:53 AM
dexy
Jan 10, 2005 10:17 AM
FLCivic
15
May 31, 2004 09:22 AM
