b16 just blew up
Old Apr 4, 2003 | 04:34 PM
DrRoboto's Avatar
Default b16 just blew up
Well, after an entire year as my daily driver, my '90 B16 crx just died on me. As I was pulling in the driveway I start hearing some awful racket coming from under the hood. Pop it open and I smell anti-freeze and the racket gets louder. Got out a flashlight, there is what looks to be antifreeze mixed with oil coming from the bottom of the timing belt cover. Do water pumps usually make loud clattering noises when they go or did something else just blow up on me?? I never changed the water pump when I did the swap, the part I got (del sol vtec?) wouldn't have fit without modification so I just took it back. Does anyone know who sells JDM water pumps for B16A1's or am I going to have to use the Del Sol VTEC one and modify some stuff?
Rob in SC
Old Apr 4, 2003 | 04:47 PM
SiR831's Avatar
Default Re: b16 just blew up (DrRoboto)
I could've sworn i used a 94 Del Sol DOHC VTEC water pump and timing belt.
Old Apr 4, 2003 | 04:49 PM
Blaze45's Avatar
Brrraaaap!
Default Re: b16 just blew up (SiR831)
It would be helpful if you posted pics where the leak is coming from. Could be a headgasket.
Blaze
Old Apr 4, 2003 | 06:08 PM
PhatOptimo's Avatar
Default Re: b16 just blew up (Blaze45)
DOHC Del Sol water pumps do fit on the JDM B16a. No modifications needed. Pull the timing covers and inspect the water pump with a flashlight. Find the leak.
Old Apr 4, 2003 | 06:44 PM
blah13's Avatar
Default Re: b16 just blew up (Phat_Optimo)
Yeah if its coming from the bootom of the cover then you'll have to pull it off, there are a few places that could be leaking, cam seals, crank seal, water pump etc. And if it looks like oil/collant that = head gasket. Hope it all turns out ok.
claymonthug
Feb 16, 2010 10:34 AM
GetawayInMoscow
Jun 27, 2005 07:43 AM
ICeDoUt
Apr 21, 2003 01:31 PM
bluecrxsi
Feb 5, 2003 07:20 PM
FOrSfEd
May 9, 2002 08:24 AM
