Please Help with Heater blower problem
Old Apr 4, 2003 | 01:45 PM
VTECAcuraGSR's Avatar
Default Please Help with Heater blower problem
Ok Guys so I only have one speed in my 93 accord. So I pull the whole dash out and test the switch and it appears to be bad, but little did I know by looking at my crappy chilton manual that there is a resistor they forgot to tell me about. Why didn't I spend the money on a Helms? Anyway, So I replace the switch and it didn't fix the problem. I am now assuming that it would be the blower resistor. Can anyone offer any insight? How do I check the resistor to see if its any good or not? Thanks!
Old Apr 4, 2003 | 03:19 PM
mrvinyl33's Avatar
New User
Default Re: Please Help with Heater blower problem (VTECAcuraGSR)
Is the one speed blowing at the highest setting? If so, then its certainly sounds like a bad blower resistor.
Old Apr 4, 2003 | 03:21 PM
Default Re: Please Help with Heater blower problem (mrvinyl33)
Yes it is the highest setting
Old Apr 5, 2003 | 11:52 AM
Can anyone add any additional comments? how do I test the resistor?
Old Apr 5, 2003 | 12:03 PM
carolinaACCORD's Avatar
if the Chilton's tells the resistance that the resistor should be at, then you need to use a multimeter to check the impedance.
sorry, i dont know what ohm's the resistor is, so i cant tell you.
Old Apr 5, 2003 | 12:08 PM
Default Re: Please Help with Heater blower problem (carolinaACCORD)
The problem is the Chiltons doesn't tell me anything about the resistor...
Old Apr 5, 2003 | 12:10 PM
Stripped Honda's Avatar
99-0104
dont worry about testing it just change it and problem will be solved
Old Apr 5, 2003 | 01:25 PM
lightningd's Avatar
Default Re: Please Help with Heater blower problem (Stripped Honda)
true dat, a resister is like a couple of cents at radio shack. if you have a soldering iron and know what you're doing it will only take a couple of minutes
Old Apr 5, 2003 | 01:28 PM
Default Re: Please Help with Heater blower problem (lightningd)
I can't just wire that kind of resister in there.... Its more like 30 bucks, not that much but its still money if thats not truely the problem.
Old Apr 5, 2003 | 02:16 PM
lightningd's Avatar
oh my bad. i haven't actually seen the resister. i thought it was one of those small ones. i stand corrected.
Old Apr 5, 2003 | 04:16 PM
Chiovnidca's Avatar
There's not a whole lot to them. There should be resistance between any combination of two terminals. You probably have at least one pair that is open.
honda dan
Dec 22, 2011 01:54 PM
turbo-2nr
Jan 22, 2009 09:47 PM
opiumdaze
May 11, 2006 08:54 PM
EK Ferio
Nov 14, 2003 06:21 AM
