Tranny problems?
Old Apr 4, 2003 | 11:42 AM
Dru-Si's Avatar
Default Tranny problems?
I just got my car back, after getting an engine rebuild and new CM Stage 1 clutch. Noticed a few problems after I got home.
1. I have trouble keeping the car in 3rd and 5th. If i shift into either gear, and releast the clutch, it'll "pop" out into neutral. If I hold it forward ( I know, not good at all), then it stays, but once I let go, it pops out again.
2. My gear positioning is kinda off now. 1st is a bit farther up, and 2nd is pretty much where neutral use to be, and everything seems shifted to the left just a bit.
Are all these problems related to shift linkage, or is it something else? This is happening on a '91 Honda CRX Si, if that helps.
Thanks!
Old Apr 5, 2003 | 10:09 AM
Dru-Si's Avatar
Default Re: Tranny problems? (Dru-Si)
Old Apr 5, 2003 | 12:19 PM
REDBARON's Avatar
Do you have tranny fluid in there? My brother had the same problem one time and the tranny had very little fluid. We re-filled it and it worked. Also did you install the shifter backwards when re-installing the shift linkage? It sounds like it may be backwards.
Old Apr 5, 2003 | 09:41 PM
FR-MOB: ThE bEe GuY's Avatar
Default Re: Tranny problems? (REDBARON)
It could possibly be the shift linkage. That happened to my friend too (except he had a B16) and he eventually discovered a screw somewhere along his shift linkage was loose or missing (i forgot which). So check the shift linkage n all its connected to to see if everythings good
Old Apr 6, 2003 | 12:01 AM
Louie B.'s Avatar
if they never opened up the tranny, it's either shift linkage or a bad engine mount. they could've messed up an engine mount when they were putting the engine back in.
jvo8
Aug 11, 2024 07:12 AM
Hatchbacksonly
Dec 2, 2012 04:20 PM
Skinnypunk
May 30, 2004 10:41 AM
89civichatchback
13
Jul 9, 2003 11:23 AM
boomslang
Nov 18, 2001 12:00 AM
