What can i use to clean my engine block????? simple green dont work
Old Apr 4, 2003 | 05:12 AM
DeDonDeRosa's Avatar
Default What can i use to clean my engine block????? simple green dont work
i tryed simple green and it doesent work for cleaning the block i need something to make it look new can anyone think of anythin that i can use to get this clean
help me out
Old Apr 4, 2003 | 05:26 AM
ki3t's Avatar
This user can set his title.
Default Re: What can i use to clean my engine block????? simple green dont work (DeDonDeRosa)
Grease Lightening from Walmart. Hope I spelled that right. Try searhing, there was a thread about this w/ pics.
Old Apr 4, 2003 | 05:58 AM
Ponch's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (B18cR-EG)
Did you have to scrub or was it a simple spray on, hose off?
Old Apr 4, 2003 | 06:45 AM
Archidictus's Avatar
Unceasing Measure
Default Re: What can i use to clean my engine block????? simple green dont work (Ponch)
Silver high-temp spraypaint. Yes, I'm serious. Easy and effective.
Old Apr 4, 2003 | 06:49 AM
B Speed's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (Archidictus)
use Gum Cutter spray, it eats away anything off of blocks. It is similar to carb & choke cleaner, but much more effective. Buy 2 cans to be safe. It is aerosol.
Old Apr 4, 2003 | 07:36 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
help me out
Did you use it correctly? Did you wet the surface slightly first, then spray it on, wait a few minutes, then spray it off? If you did not use a pressure washer, I highly recommend it. If the engine is in the car, drive it to a car wash and spray it down. If the engine is out of the car, throw it in the back of a pickup and take it to the car wash. Use a spray bottle to wet the surface (so you don't waste time on the car wash clock), spray on the Simple Green in the full strength concentrate, let it sit for 4-5 minutes, then use the pressure washer to clean it off. Works wonders for my engine bay.
Old Apr 4, 2003 | 08:17 AM
Hatchy-Ownzjo0's Avatar
H-T Poker champion
Default Re: What can i use to clean my engine block????? simple green dont work (PatrickGSR94)
Make sure you use the AUTOMOTIVE Simple Green. If you have just the regular Simple Green cleaner it won't work nearly as well.
edit: The Automotive Simple Green cleaned my block very well. All i did was spray it on, then wipe it off after like 10 - 15 seconds. Got all the oil and grime off no problem.
[Modified by Hatchy-Ownzjo0, 12:17 PM 4/4/2003]
Old Apr 4, 2003 | 08:23 AM
G a b e's Avatar
Banned
Default Re: What can i use to clean my engine block????? simple green dont work (Hatchy-Ownzjo0)
When I cleaned my block, I used Brake Cleaner, scrub, spray simple green, repeat if necisary.... granted this was out of the car, that I stripped down to almost nothing, with the intention of cleaning it... but it worked.
Old Apr 4, 2003 | 08:38 AM
blackANESE's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (G a b e)
THis stuff
[Modified by blackANESE, 9:38 AM 4/4/2003]
Old Apr 4, 2003 | 08:54 AM
IntEGNYC's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (blackANESE)
THis stuff
and there's 20% free
Old Apr 4, 2003 | 08:56 AM
ScaleExtric's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (IntEGNYC)
Gunk is the ****...get that..only that sucks about Gunk is that ...after you use it..it smells like **** in your interior..from the fumes. Hey where the hell did you get the 20% free Gunk?
Old Apr 4, 2003 | 09:00 AM
Steve Berman's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (ScaleExtric)
LMAO. Gunk will cause some dry specs too becasue its soo strong.
When that happens I just hit everything up with a light touch of WD40
Old Apr 4, 2003 | 10:54 AM
EKFerioHawaii's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (Steve Berman)
Of course you could always hot tub it at your local machine shop.
Old Apr 4, 2003 | 11:06 AM
fiebru1119's Avatar
Default Re: What can i use to clean my engine block????? simple green dont work (EKFerioHawaii)
I had the cylinder head of my last car (after everything was removed) sandblasted.. man that thing was blingin
Peter Brady onlyonweekndz
Nov 26, 2007 12:55 AM
HarfordCTR
Aug 14, 2007 12:13 PM
d16dcoe45
Aug 22, 2005 04:31 AM
B_CRUZ!
Mar 14, 2002 06:30 AM
keithv
Jun 14, 2001 06:44 PM
