has anyone dealt with a b16 front clip????
I was just wondering about the front clip. If you got the front clip you wouldn't have to buy axles, mounts, shiftlinkage, you would get a cross-member that you can use a 4-1 header without notching, or having to buy an aftermarket one . Also get the guage cluster, ac bracket, brakes, etc.
I just wanna know If I still would have to buy the normal swap items for the b16 swap in a ef.
[Modified by 89civ, 1:25 AM 4/4/2003]
although the front end will come with the mounts you will not be able to just bolt the motor into you car. The jdm body has different factory mounting locations so you will need to either fab some mounts yourself or buy a mounting kit. Oh and the x-member will not go on either.
thanks I was just wondering if it would work.
what else can I use from the front clip?
[Modified by 89civ, 1:46 AM 4/4/2003]
Engine, Tranny, Axles, ECU, engine harness, A/C stuff, Bumper Cover, Radiator support, Radiator, headlights, corner lights, bumper lights, filler panel, hood, brake booster, master cylinder, proportioning valve...
LOTS.
Pretty much anything you FEEL like swapping over.
LOTS.
kevheslop
Aug 27, 2009 04:21 AM
Mackenzie
25
Dec 20, 2004 04:05 PM
