89 integ eng. in a crx?
Old Jun 20, 2001 | 05:28 PM
RICEBURNER1406's Avatar
New User
Default 89 integ eng. in a crx?
will a 89 integ 1.6 dohc fit in an 89 crx si with no mods to the motor mounts? i have the whole integ car so if someone could please guide me to what i need i would appreciate it!! thanks guys!!
Old Jun 20, 2001 | 08:44 PM
memphiss13's Avatar
Default Re: 89 integ eng. in a crx? (RICEBURNER1406)
it is a detuned zc motor, it will fit. but why would you want to do this. that motor sucks. sell that old teg. my friend has one of those and he even knows that the motor is a TURD
Old Jun 20, 2001 | 11:36 PM
SkotEZ's Avatar
you can do the swap, but you need to use your existing motor mounts, however, i don't reccomend the swap for the 5-8 hp it will give you. do the ZC swap its actually easier, and use the teg ecu
Old Jun 21, 2001 | 12:16 AM
New User
Default Re: 89 integ eng. in a crx? (HondaGuruTX)
its for a friend of mine and i guess he really wants to do it because he's got the engina already. so it will drop right in with the old mounts on the integ? thanks guys i appreciate it.
Old Jun 21, 2001 | 07:13 AM
SkotEZ's Avatar
it will not bolt in with the teg mounts, you will need to use the mounts from the civic
Old Jun 21, 2001 | 02:54 PM
Sonic's Avatar
Good luck, the motor mount locations are different...you won't get it to fit. I put a D16A1 block and a ZC next to each other in my garage and guess what, the only difference was in the mount holes...there is one that is needed for the drivers side mount in the crx that isn't there on the 1g teg motor...it's not going to fit, don't waste your time. If you want something to put it in, it will fit in an 85-87 CRX, and be really fun to drive...that's what I have in my 86 Si.
Old Jun 21, 2001 | 03:12 PM
LowSiR's Avatar
New User
Tell you what for the looks is cool, for performance, ah..., better stick with the D16A. First the D16A has way more aftermarket crap. Personal opinion I would sell it and save for a B16A from a Del Sol, now that's cool for about $1500 to $2000. My CRX has B16A ***** and its fast, I never race, it has nothing but outside mods and I keep up with Camaros and Mustangs.
P.S. The ZC engine is way too heavy compared with the gain on power.
Old Jun 21, 2001 | 07:12 PM
c-rex's Avatar
Default Re: 89 integ eng. in a crx? (LowSiR)
89 D16A is harder to put in a 1g rex vs. an 86-87 D16A. Wiring is different. 86-87= bolt in 88-89=mod to fit (with wiring, you actually could swap over all the electrical from an early teg though)..Hmm.....Bet a B16A easier, cheaper, more power. Nuff said.
~C~
h22_crx
Sep 6, 2005 07:14 PM
curt801
Nov 5, 2004 03:42 PM
PhatOptimo
Oct 20, 2002 03:59 PM
vtec_head
Apr 22, 2002 02:26 PM
Type-ARR
Aug 5, 2001 05:58 PM
