speedo cable on b18? HELP
Old Apr 3, 2003 | 06:37 PM
iwouldHITit's Avatar
Default speedo cable on b18? HELP
i have a crx and just swaped a b18 in... do i have to do anything to the speedo cable.. it looks like that mines is to short and doesnt go into the vss all the way in...
Old Apr 3, 2003 | 07:27 PM
Default Re: speedo cable on b18? HELP (iwouldHITit)
need help
Old Apr 3, 2003 | 07:54 PM
sCeRaXn's Avatar
Honda-Tech Double Platinum Member
What year/model is it? I just swapped my 1.8 in a few weeks ago and my 90 dx cable fit it with a little slack left over. You might have to re-route it if its hitting any other cables or hoses...thats what i had to do. IM me if you have any questions(if its that or anything else about the swap). Then go out and enjoy all that torque...i know i do.
Sean
Old Apr 3, 2003 | 10:07 PM
Default Re: speedo cable on b18? HELP (sCeRaXn)
i got a 89 hf crx..it seems like the rear mount bracket is getting in the way..
Old Apr 5, 2003 | 02:05 PM
should i just cut out a section of the bracket??
Old Apr 5, 2003 | 02:22 PM
Flexmyrex's Avatar
is that a b series vss or did you swap it from your crx tranny, the crx vss wont work
make sure it clips in there, what i do is put my car in neutral and push it back slowly while i push the clip in
Old Apr 5, 2003 | 03:07 PM
Default Re: speedo cable on b18? HELP (flexmyREX)
yes thats a Bseries vss..what clip are you talking about? the speedo cable doesnt even go in the vss all the way...
Old Apr 5, 2003 | 05:35 PM
uneek4dr's Avatar
Why would you even think about cuttin that bracket???
just run the cable on the other side of it
Old Apr 5, 2003 | 06:05 PM
CrxSi10's Avatar
NO. All you have to do is get the speedo cable from an older integra. I have this in stock and all you have to do is pay for shipping and I'll send it to you. I had this problem before and fixed it with the 89 integra speedo cable. Since I installed a GSR gauge cluster in my car, I don't need it anymore and you can have it, just pay for shipping. Trust me, I'm right.
corey89crx
20
Dec 7, 2009 03:31 PM
type Gendy
Mar 11, 2009 01:28 PM
5litereater
Jun 14, 2004 01:55 PM
not so civic
Jun 11, 2002 07:08 PM
Kataku2K3
Apr 28, 2002 07:51 AM
