Air/Fuel Gauge Install
Old Apr 3, 2003 | 06:19 PM
BlackB18CTeg's Avatar
Default Air/Fuel Gauge Install
Anyone have any websites that show how to do Air/Fuel Gauge install? I know that they said to tap into the o2 sensor, but i have a 95 and the o2 is under the car. is there any other way?
Old Apr 3, 2003 | 06:37 PM
neo1z's Avatar
Default Re: Air/Fuel Gauge Install (BlackB18CTeg)
Instead of tapping that wire down by the header...you can tap the only pure white wire going to the ECU -- thats what I did -- works great.
Old Apr 4, 2003 | 06:24 AM
Default Re: Air/Fuel Gauge Install (neo1z)
where is the white wire? how and where do i access it and what gauge wire is it?
Old Apr 4, 2003 | 06:27 AM
StyleTEG's Avatar
I did the same, but there were at least 3 pure white wires on my ECU (96 B18B). It was the last wire I tried of cource
Old Apr 4, 2003 | 09:07 AM
Default Re: Air/Fuel Gauge Install (StyleTEG)
where did you access the wire though? near the ECU itself? or somewhere else?
Old Apr 4, 2003 | 09:45 AM
allmotorls95's Avatar
isn't it the blue wire...
Old Apr 4, 2003 | 11:09 AM
StyleTEG's Avatar
Yeah, if you remove the two bolts that hold the ECU down, you can disconnect the wire harnesses at the bottom. It should be on there. I used a plastic wire tap, made things easier.
All my A/F gauge tells me is that I am running rich all the time. wooo.
Old Apr 4, 2003 | 12:43 PM
neo1z's Avatar
I just soldered it. You could do either -- I feel cool soldering though
The P72 has only one pure white wire with no other markings. So, youll be able to find it - is your GSR obd2 or 1?
Old Apr 4, 2003 | 01:50 PM
SHystrdyGSRtdy's Avatar
So which wire is it? Blue or white for 99 gsr? O well...when my helms comes in..i'll let you guys know
Old Apr 4, 2003 | 03:37 PM
Default Re: Air/Fuel Gauge Install (iLUVmySH)
its obd 1, so i think its one wire thats white
Old Apr 4, 2003 | 05:55 PM
i hooked up my gauge to the white and red stripe wire, however it says rich all the time. this what it says when its not hooked up at all also, so i think i got thewrong wire.... but if you check out
http://www.team-integra.net/sections...670&search=pod
its the right wire.
Old Apr 5, 2003 | 06:45 PM
greekspeed's Avatar
Which wire is the O2 sensor wire on the ob2 ecu's for b18b
(Im speakign of the Front senor that is mounted on the header, not the one that is on the cat)
Old Apr 5, 2003 | 09:14 PM
JDubya's Avatar
Default Re: Air/Fuel Gauge Install (greekspeed)
for an OBD2 b18b its the all WHITE wire. Make sure its not the white wire w/silver dots, i just installed my a/f gauge and had it hooked up to that wire and I thought something was broken, but it turns out it was just the wrong white wire The wire u need (all white) will be on the smallest of the 3 clips going into the ECU.
chrisfromsrq
Jul 30, 2009 09:47 AM
92prelude23
Nov 17, 2008 02:09 PM
boostng r
Sep 18, 2004 10:57 AM
Tad
23
Nov 13, 2003 11:24 AM
