minor scratches on cams... should i be concerned?
Old Apr 3, 2003 | 05:39 PM
B18EG6's Avatar
Default minor scratches on cams... should i be concerned?
Recently I rebuilt my head. Upon replacement of the cams I lubricated them generously with assembly lube from honda. recently I removed them to retighten the head studs and noticed slight scratches on the cams where they meet the journals. These scratches are very minor and the depth of them cannot be scratched by my fingernails.
Are my cams not getting enough oil? Did I not lubricate them enough when I replaced them in the head? I tightened down the cam caps to spec, 22 ft/lbs.
thanks.
Old Apr 3, 2003 | 06:09 PM
Tweakmeister's Avatar
Default Re: minor scratches on cams... should i be concerned? (B18EG6)
pics?
if you can't scratch them with your fingernail...are you sure they're scratches?
Old Apr 3, 2003 | 06:30 PM
Kamin's Avatar
you sure it isnt just normal wear marks? if you cant feel it with your fingernail dont worry
Old Apr 3, 2003 | 08:50 PM
B18EG6's Avatar
Default Re: minor scratches on cams... should i be concerned? (Kamin)
Ill get pics tomorrow... Im going home to work on my car.
I def cannot scratch them with fingernail, I am not concerned too much. Pics will come tomorrow.
thanks
Old Apr 6, 2003 | 12:53 AM
B18EG6's Avatar
Here are pictures...
whatcha think?
[Modified by B18EG6, 4:53 AM 4/6/2003]
Old Apr 7, 2003 | 12:59 AM
B18EG6's Avatar
wow..moved faster than i thought.... to the top
Old Apr 7, 2003 | 01:04 AM
NiiS's Avatar
If they looked like that after one day, I`d be concerned, but normal wear and tear would probably do that same markings, atleast mine did. But what do I know, I broke an intake cam and bent a dozen valves in one week LoL
Old Apr 7, 2003 | 06:01 AM
kyle h.'s Avatar
Default Re: minor scratches on cams... should i be concerned? (sinister)
check the journal. it might have some scratches in it. they dont look that bad, as long as you cannot feel them, i wouldnt worry yet.
Old Apr 7, 2003 | 04:05 PM
B18EG6's Avatar
Default Re: minor scratches on cams... should i be concerned? (kyle h.)
journals look fine... Maybe I should use more assembly lube next time, I dunno.. I used a whole tube though!
thanks for looking.
Old Apr 7, 2003 | 04:57 PM
kyle h.'s Avatar
na, i dont think u need to use that much.
madblkscientist
22
Jun 25, 2011 03:42 AM
psegs80
Oct 31, 2009 11:25 AM
Murk 'EM
Sep 4, 2007 10:32 PM
davidluko
19
Dec 13, 2006 10:32 PM
Red99CivicSi
Mar 2, 2003 07:32 AM
