USDM ITR pistons in B16A ?
Old Apr 3, 2003 | 05:11 PM
fsarfino's Avatar
Default USDM ITR pistons in B16A ?
Couple of quick ?'s
What kinda compression ratio would I have with these pistons? I would be using a Honda headgasket, is NOT milled.
Does Anyone here know if I would have valve clearance issues with Crower 63402 cams and the USDM ITR pistons.
Thanks.
Old Apr 3, 2003 | 06:37 PM
eg6ajk's Avatar
Default Re: USDM ITR pistons in B16A ? (fsarfino)
you will have nice and low c/r of around 9.7:1 ( almost just like the d16y8 in the EX coupe)
there should be no clearance issues.
do yourself a favour and run the PCT (b16b) CTR pistons if you can that should put you at 10.8:1 or so. more aggressive cams require higher compression.
Old Apr 3, 2003 | 06:53 PM
fsarfino's Avatar
Default Re: USDM ITR pistons in B16A ? (eg6ajk)
I thought it would be around 10.6 - 10.8
Old Apr 4, 2003 | 01:10 PM
fsarfino's Avatar
Old Apr 4, 2003 | 01:16 PM
stevel's Avatar
No way does ITR pistons make the CR that low. The stock is higher than that. I would assume you're keeping stock rods. It is almost exactly the same as stock actually, 10.2:1. If you run the pct pistons and spoon headgasket your CR would be 11.17:1 or so.
s
[Modified by stevel, 5:17 PM 4/4/2003]
Old Apr 4, 2003 | 01:31 PM
ATYPR's Avatar
Default Re: USDM ITR pistons in B16A ? (stevel)
http://www.c-speedracing.com/howto/c...c/compcalc.php
Old Apr 4, 2003 | 02:26 PM
fsarfino's Avatar
Default Re: USDM ITR pistons in B16A ? (FUCATYPR)
Thanks for the link
Old Apr 4, 2003 | 02:42 PM
sweet's Avatar
all you have to do is go to c-speedracing.com like already stated to get the different C/R's.
people have to remember that the B16A pistons are the highest domed B series pistons, other than the CTR/B16B pistons (which most use for a higher C/R).
the USDM B16A is 10.2:1 and the JDM B16A is 10.4:1 C/R. so with the JDM B16B pistons in a B16A the C/R goes up to 10.8:1, which was already mentioned above.
just because it's a Type R piston doesn't mean it's going to give a higher C/R than the stock SI pistons. the JDM ITR pistons are almost identical to the B16A pistons so you still get 10.2:1 C/R if you swap them out and leave everything else the same, including the HG thickness.
blackeg
21
Jan 4, 2012 04:16 PM
hwt101
Mar 20, 2009 03:11 PM
stonet149
12
Nov 2, 2008 09:29 PM
boobz
Jul 25, 2004 08:48 PM
HybriDNA
Aug 28, 2002 08:53 AM
