ls vtec distributor question???
Old Apr 3, 2003 | 05:05 PM
delux247's Avatar
Default ls vtec distributor question???
i have a 1995 ls integra and i want to put my 99 b16a head on the block
will my obd2 distributor from the head work or the ls dist. or do i have to get a new dist.
thanks
Old Apr 3, 2003 | 08:34 PM
delux247's Avatar
Default Re: ls vtec distributor question??? (egcivicturbo)
please help anyone
Old Apr 4, 2003 | 05:11 AM
delux247's Avatar
help
Old Apr 4, 2003 | 05:48 AM
crxONcrack's Avatar
if the plugs match, they should work....both cars are obd2.................
Old Apr 4, 2003 | 07:48 AM
Rod.'s Avatar
Im having that same problem. I have a 95 ls with a drag turbo setup and i getting a b16 head. Do you have your bottom end built?? if you do did you sleeve it????
Old Apr 4, 2003 | 08:34 AM
omahaturbocivic's Avatar
Default Re: ls vtec distributor question??? (crxONcrack)
a 95 integra ls is obd1, 96 and newer is obd2. If the integra one will bolt up to the b16 head it should work.
Old Apr 4, 2003 | 08:44 AM
CRXGSR's Avatar
Use the correct distributor for the correct computer. If computer is obd1, use the obd1 distributor and vice versa.
I think you'll have to use the LS distributor, and chop off one of it's mounting points to bolt it up to the B16A head.
Old Apr 4, 2003 | 08:59 AM
1.8EG-T's Avatar
Default Re: ls vtec distributor question??? (CRXGSR)
Buy a OBD1 vtec dist., you will never get the timing(exactly) correct...if you plan on forced induction this could be a big deal.
Old Apr 4, 2003 | 01:54 PM
AzN_Flava's Avatar
Default Re: ls vtec distributor question??? (hybridrex)
ah crap,
so there is no way to make an obd2 distributer work with an obd1 ecu?
Old Apr 4, 2003 | 01:56 PM
simple4012's Avatar
New User
Default Re: ls vtec distributor question??? (AzN_Flava)
no thats not true. all 92+ dist are the same (mounting legs aside) simply rewire it and ya good to go. the colors are there on both sides but in different spots. just match em up and go
Old Apr 4, 2003 | 01:57 PM
simple4012's Avatar
New User
Default Re: ls vtec distributor question??? (simple4012)
i meant 92+ b series BTW
Old Apr 4, 2003 | 02:55 PM
sweet's Avatar
yes i was told recently that all you have to do is rewire the pins on an OBD2 dist. so it'll work with an OBD1 harness and ECU. i haven't tried this yet to see, but i'm sure it's true.
check it out and just rewire the plugs, the you can use the newer dist. you have and not buy an OBD1 which can cost a bunch depending on the year/condition.
Old Apr 4, 2003 | 02:58 PM
AzN_Flava's Avatar
Default Re: ls vtec distributor question??? (sweet)
WOO HOO,
anyone wanna give me the colors or what to do, to wire it?
Old Apr 4, 2003 | 03:06 PM
sgT's Avatar
sgT
if you are using the 95 integra harness, then you can use the 95 distributor, you
just have to modify the dist slightly to fit the head.
you need the dist that matches the harness you are using, either 92-95 or 96+
Old Apr 4, 2003 | 03:39 PM
AzN_Flava's Avatar
Default Re: ls vtec distributor question??? (sgT)
if i used an 96 wire harness, does that mean i become obd2?
can i use the 96 wire harness, 96 distributer, but use an obd1 ecu?
delux247's Avatar
thanks for all the help
btw has anyone ever rewired the obd2 to work on obd1???
Old Apr 4, 2003 | 04:11 PM
simple4012's Avatar
New User
yes. the wires are the same colors just moved into different spots on the plugs. simple match the distributor wires up to the harness wires.....just match colors
Old Apr 4, 2003 | 05:48 PM
b19coupe's Avatar
You have another option: if you are mechanically inclined you can swap the guts out of your OBD1 LS distibutor into your OBD2 B16 distributor. That's what I did.
Old Apr 4, 2003 | 05:57 PM
AzN_Flava's Avatar
Default Re: ls vtec distributor question??? (b19coupe)
ah yes, i'm decently inclined?haha but my friends are all better off, im sure they can help me out...
woo hoo, i get to save the hassle of seling my obd2 b16 dist and buying another one..
thanks a lot guys...
Joacnel
Engine Management and Tuning
Apr 4, 2012 07:02 PM
nikkarocky
Apr 10, 2007 12:54 PM
VTECth1s
Jun 5, 2006 04:09 PM
6doorsentra
May 30, 2006 07:12 PM
jeremy.
Dec 19, 2003 07:40 AM
