Need help installing GC coilovers with kyb agx!!!!!
Old Apr 3, 2003 | 04:52 PM
CrxSi10's Avatar
Default Need help installing GC coilovers with kyb agx!!!!!
Damn archive search is disable. I'm only having problems with the rear shocks. I have instructions for the install. It says to put the rubber sleeve on the rear shocks then put the coilover over the sleeve. Problem is that the coilover won't fit over the sleeve. I tried splitting the sleeve into 2 small pieces and will only get coilover to go down half way. Any body with any info or help is greatly appreciated, thanks.
Old Apr 3, 2003 | 04:59 PM
unabonger's Avatar
Default Re: Need help installing GC coilovers with kyb agx!!!!! (CrxSi10)
hmm are you talkin bout the dust cover, you dont need those... and remember to use only half of the bumpstops cut half and use only half.
Old Apr 3, 2003 | 05:03 PM
CrxSi10's Avatar
Default Re: Need help installing GC coilovers with kyb agx!!!!! (unabonger)
No, it's just that I can't get the coilover to fit over the rubbler sleeve (that came with the kit by GC).
Old Apr 3, 2003 | 08:58 PM
andrew dc's Avatar
used the rings that came with the gc.. the rubber band like thing... I had this problem too.. I used eg shocks in my ef with DA GC spring rates.. I went to osh (hardware store) to get some rubber material that was thinner and did not tear, then taped it to the shock body... slid the coil over over, and there you go!
Old Apr 3, 2003 | 09:01 PM
the DR.'s Avatar
Default Re: Need help installing GC coilovers with kyb agx!!!!! (CRX25)
just use the o-rings (the thicker ones) that came with the kit and you should be fine
Old Apr 4, 2003 | 03:39 PM
CrxSi10's Avatar
Default Re: Need help installing GC coilovers with kyb agx!!!!! (SlicedBread)
Do you mean I should just use acouple of those o-rings on the strut and slide the coilover over it? Thanks for the info so far.
EdWord
Apr 5, 2010 06:10 AM
Jamez
Oct 5, 2004 10:55 AM
Attoir
Feb 19, 2004 05:24 PM
justininhifi
Apr 30, 2003 12:25 AM
