disconnecting knock sensor with no CEL
Old Apr 3, 2003 | 03:22 PM
PhatHardy's Avatar
Default disconnecting knock sensor with no CEL
is it possible to not hook up the knock sensor to the knock sensor but hook it up to the ecu and make it so it doesn't have a CEL, like ground the wire out, or hook it up to a +12v, thanks
Old Apr 3, 2003 | 03:31 PM
turbohf's Avatar
Default Re: disconnecting knock sensor with no CEL (PhatHardy)
i dont think VTEC will turn on without it hooked up...
Old Apr 3, 2003 | 03:46 PM
zCivic's Avatar
Default Re: disconnecting knock sensor with no CEL (turbohf)
yeah just ground it and that should be fine. Don't connect to 12volts will fry knock board. You can also wire in a resistors but grounding it is a ez fix
Old Apr 3, 2003 | 06:31 PM
PhatHardy's Avatar
Default Re: disconnecting knock sensor with no CEL (zCivic)
turbohf that's not true, mine isn't hooked up right now and i have plenty of vtec but thanks for the grounding out option. So should i just ground it out and then reset the ecu?
BILLisCHILL
May 8, 2008 06:40 PM
jdmdseries
Nov 16, 2007 03:46 PM
s_vares
Sep 3, 2006 02:54 PM
petarr
Mar 4, 2006 10:37 AM
