sypmtoms of bad fuel pump?
Old Apr 3, 2003 | 01:46 PM
TheOne's Avatar
Default sypmtoms of bad fuel pump?
how do you know when the fuel pump is going bad.
Old Apr 3, 2003 | 01:51 PM
Diego Boost's Avatar
Default Re: sypmtoms of bad fuel pump? (TheOne)
It usually starts getting obnoxiously loud, causes you car to hesitate/sputter, or your car will just die completely.
Old Apr 4, 2003 | 04:14 AM
TheOne's Avatar
Default Re: sypmtoms of bad fuel pump? (Diego Boost)
so it will come and go (the symptoms) and then it will eventually not work? That is what my car is doing but I thought it was wierd that it works sometimes and then my car will sputter, sometimes backfire, and then die other times. do you think that I could use a stock fuel pump instead of my walboro if I have hondata and 450 injectors (I am running 7 pounds of boost)?
Old Apr 6, 2003 | 06:07 PM
boobstar's Avatar
ttt cause i have the same problem and i want to know the answer, im about to get a walbro on stock injectors
Old Apr 6, 2003 | 08:16 PM
filthy scarecrow's Avatar
Default Re: sypmtoms of bad fuel pump? (boobstar)
usually hard starting is a symptom too. the pump can't prime the rail with enough pressure to get decent atomisation so it takes some cranking to start.
a stock fuel pump should be fine with 7psi of boost.
peaNUTS6
Honda Civic (2001 - 2005)
Apr 2, 2007 11:30 AM
Todapwr
May 12, 2004 07:51 PM
switchblade
Apr 24, 2004 02:07 PM
Screamer
Jun 18, 2003 09:17 AM
ridnmyhonda
Apr 1, 2003 01:00 AM
