Oil on sparkplugs #2 and #3. is it the sparkplug gasket?
Old Apr 3, 2003 | 07:21 AM
fasteddy91's Avatar
Default Oil on sparkplugs #2 and #3. is it the sparkplug gasket?
Hi everyone,
I just bought a 95 integra LSS, with 95k miles. The car had the 90k major service (spark plug wires, timing belt, water pump, all accessories belts, valve cover gasket and spark plug gaskets) done recently. I just replaced the cap and rotor, and spark plugs. I noticed spark plug #2 and #3 had some oil on it. it looked fresh, like it was coming from the top and not from the pistons. I went ahead and changed them and after a couple days and I reinspected them again. This time I could tell the oil is coming from the top, because the oil is on the thread of the spark plug where the sparkplug washer is located to about half way down. The rest of the plug where the electrode and insulator is dry. Is this a sign of a bad spark plug gasket? spark plug tube? Any info would be appreciated. BTW I did do a search as well.
Thanks,
Eddy
Old Apr 3, 2003 | 07:48 AM
tilt's Avatar
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (fasteddy91)
It's probably a bad seal on the rubber gasket ring thing. Look carefully inside the sparkplug hole just below the valve cover there are black rubber rings.. see if it is pinched or there is oil there.
Old Apr 3, 2003 | 07:52 AM
ek44's Avatar
first check if u had any stud bolts busted.
then check valve cover bolts tq spec cuz if this is too loose it will also leak into the plugs.
if all were tq properly then u need to replace spark plug gasket set(s). u need to change all 4.
hope this helps.
Old Apr 3, 2003 | 07:55 AM
fasteddy91's Avatar
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (ek44)
Thanks guys! I checked all the valve cover bolts and they all seemed fine. I did noticed that there is a little oil in the spark plug hole toward the bottom on cylinder number two and three.
Thanks!
Eddy
Old Apr 3, 2003 | 08:00 AM
MugenGTR's Avatar
yea, it's probably the spark plug gasket, jus get that checked out, it shouldn't be anythin serioius.
Old Apr 3, 2003 | 09:43 AM
Gee3's Avatar
From: Formerly of SF moved to DFW and now back in SF, CA, USA
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (MugenGTR)
Pull the vavle cover off and see if the rubber gaskets to seal the spark plug holes are damaged.
Old Apr 3, 2003 | 10:56 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
I recently changed all the gaskets on the top end of my engine. I had a very slight oil leak and/or oil burning before then, now my engine's oil consumption/loss is ZERO, and my engine has 133K miles on it, VTEC'd daily.
The plug tube gaskets are only $2-$3 each, just go ahead and change them.
Old Apr 3, 2003 | 12:16 PM
SMZ GSR's Avatar
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (PatrickGSR94)
the valve cover gasket and the 4 spark plug gaskets cost less than $20. might as well just change them all at once.
Old Apr 3, 2003 | 12:47 PM
Aaron M's Avatar
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (SMZ GSR)
how exactly do those gaskets go bad, they seem like very durable rubber
Old Apr 3, 2003 | 01:19 PM
Community Builder
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (SilverB18C1)
extreme temperature changes will definitely help wear out seals (think of the temperature range from when the engine is cold to normal operating temps).
Old Apr 3, 2003 | 05:14 PM
ineedateg's Avatar
hey im having the same problem with my teg. can i buy these parts at a pep boys or do i have to go to a acura/honda dealer? how hard is it to replace these parts? thanks for the help
Old Apr 3, 2003 | 06:29 PM
PSU-TEG's Avatar
Default Re: Oil on sparkplugs #2 and #3. is it the sparkplug gasket? (ineedateg)
Auto Zone..... $3 for the set of 4. But they had to order them (took 3 days). Although, I'm sure Honda/Acura would too... they never stock anything!!
I have the same problem in the #1 Spark plug tube. I'm replacing my tomorrow.
I'm sure Auto Zone or Pepboys will work just as good as Honda/Acura. I'll let you know next week.
Old Apr 3, 2003 | 08:18 PM
ineedateg's Avatar
anybody know where i can get a diy on the gasket change?
1990 rs btw
Old Apr 4, 2003 | 05:12 AM
fasteddy91's Avatar
Well Guys, if you need parts on the spot go to Acura of Concord if you are in the bay area. i'm still batting a thousand on getting parts without having to wait. I just bought the gasket kit which includes valve cover gasket @12.10 and the sparkplug gaskets for 3.05 a piece I think, for a total of 26.89 including taxes. I had bought a bunch of other stuff the other day and everything was in stock
Btw, thanks for everyone's advice on my oil leak!
Eddy
Old Apr 4, 2003 | 06:05 AM
JimBlake's Avatar
1990 rs btw
1) remove spark plug cover plate
2) remove spark plug wires with their plastic clip holders
3) remove valve cover
4) take out valve cover gasket & 4 sparkplug tube gaskets
5) put in new gaskets
5a) maybe VTEC valve O-ring, too? (well, not on an RS)
6) HondaBond (or some sealant) at the corners where the gasket goes over the cams
7) put all the other stuff back together - don't forget the ground wire
Can't think of many easier DIY jobs, except maybe filling you washer fluid...
Notice how the old gaskets have gotten kind of hard & maybe even shrunk? That's what goes wrong with them... If you'd like to invent some kind of rubber that doesn't do that, & doesn't cost a million$ a pound, we'd all appreciate it.
Old Apr 4, 2003 | 08:43 AM
IntEGNYC's Avatar
Eddy
I bought stuff at autozone and R&S strauss and they were always somewhat off with the fit or threads. I'd suggest the dealer for proper fit.
rjmancia
15
Sep 13, 2008 08:57 AM
VTEC_Du_Ma_Mai
Sep 6, 2008 11:08 AM
ajn22anellie
Sep 13, 2007 03:07 PM
luciffer
Mar 18, 2005 07:43 AM
capcon83
Apr 23, 2002 11:21 PM
