5th Gen owners with OBD 1, running a P13 ECU?
Old Apr 2, 2003 | 08:17 PM
kotetu's Avatar
Default 5th Gen owners with OBD 1, running a P13 ECU?
How many 5th Gen owners have gone to OBD I using a P13 (4th Gen Prelude VTEC) ECU?
Was there any trouble, modification, problems, etc?
Please be specific with as much detail as you can. I'm trying to become very familiar with any issues.
Thanks!
[Modified by kotetu, 4:46 PM 4/3/2003]
Old Apr 3, 2003 | 07:45 AM
kotetu's Avatar
Default Re: 5th Gen owners with OBD 1, running a P13 ECU? (kotetu)
ttt. Anyone? I can't search the archives, so I am posting now.
Old Apr 3, 2003 | 10:22 AM
vtecfiendsh's Avatar
bump i would like to hear this also....
id like to do it so i could get rid of the catalytic converter and run a test pipe instead
Old Apr 3, 2003 | 10:50 AM
Anubyss's Avatar
Default Re: 5th Gen owners with OBD 1, running a P13 ECU? (vtecfiendsh)
I didn't know p13 was even an option (it's not listed on Hondata's site). I know p72 and p28 are popular. I am using a p28.
Old Apr 3, 2003 | 08:14 PM
kotetu's Avatar
Default Re: 5th Gen owners with OBD 1, running a P13 ECU? (Anubyss)
I'd like to search for this topic in the archives, but since they are disabled right now...
I remember reading a thread about ECU's, it seemed a lot of ppl went with reprogrammed GSR ecus. I don't remember what was said about the P13, which afterall is the 4th gen Prelude ECU.
The only thing I have heard about it recently is that it was made with smaller injectors in mind, and that some people have no problems.
I just want as much detail as I can get.
Old Apr 4, 2003 | 06:08 AM
Jason kiDD's Avatar
When going from ODB II to ODB I all you have to do is change the ECU and the distributor and you are set.. The difficulty comes where your harness is ODB II and you just have to make some adjustments to the distro wiring and you may have to get a conversion harness on the ECU side for it to plug up..
And that is all..
Old Apr 4, 2003 | 08:48 AM
kotetu's Avatar
Default Re: 5th Gen owners with OBD 1, running a P13 ECU? (Jason kiDD)
And that is all..
Thanks, Jason Why do you need to change the distributor ?
Old Apr 4, 2003 | 08:59 AM
Jason kiDD's Avatar
I believe with ODB I the crank angle sensor and some other sensor are held within the housing.. On ODB II cars they are in the timing belt area..
Dont quote me on it though.. hehe
Old Apr 4, 2003 | 09:27 AM
kotetu's Avatar
thanks
Old Apr 4, 2003 | 09:31 AM
YumVTEC's Avatar
talk to Poison, he's running an obd1 p13 in his 5g ex coupe with jdm h22 swap
Old Apr 4, 2003 | 09:33 AM
kotetu's Avatar
Default Re: 5th Gen owners with OBD 1, running a P13 ECU? (YumVTEC)
cool! thx.
Old Apr 4, 2003 | 09:41 AM
Jason kiDD's Avatar
And what am I? Chopped liver??
98 JDM Type S-spec
93 Civic
p13 Spoon Chipped ODB I ECU
Current status: Disabled because of timing.
Old Apr 4, 2003 | 09:42 AM
YumVTEC's Avatar
98 JDM Type S-spec
93 Civic
no offense was intended in my post. i just know poison personally.
Old Apr 4, 2003 | 09:58 AM
Jason kiDD's Avatar
Twas a joke!!
Old Apr 4, 2003 | 02:09 PM
piotrush's Avatar
Unfortunately for SH owners, we can't change the ecu without losing atts. But if you can live without it than its no big deal.
BTW, this is a bit OT, but is there any way to raise the redline and still retain the stock ecu? I want to know because I plan on upgrading my cams somewhere down the line and I dont want to switch the ecu. thanks.
Old Apr 4, 2003 | 02:41 PM
Jason kiDD's Avatar
Default Re: 5th Gen owners with OBD 1, running a P13 ECU? (piotrush)
The only way would be to chip the ECU with either the SPOON Program or another similar one.
macsmurray
May 13, 2006 05:15 PM
pkt1213
Feb 24, 2005 06:38 AM
4thgenlude
Dec 15, 2004 05:36 PM
Boostless-Lude
Jun 8, 2004 03:50 PM
pr0digy1
Jan 24, 2002 04:43 PM
