ITR Tranny Synchros' w/o the gears
Old Apr 2, 2003 | 08:03 PM
Christian's Avatar
Default ITR Tranny Synchros' w/o the gears
I need a full set of ITR tranny syncro's for me without the gears. I know the US dealers only sell synchro's with the gears but I have heard that outside of the states dealers can get just the synchros. I need them ASAP.
Old Apr 2, 2003 | 08:14 PM
sackdz's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (Christian)
Last time I ordered synchros they were available seperately (from Mike K)
Old Apr 2, 2003 | 08:43 PM
bus stop's Avatar
did u try to contact LEN to see if he can help you on this one ??
Old Apr 2, 2003 | 09:09 PM
Christian's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (WhosITR)
Thanks Oscar ... I will call him in the AM... where is he located?
Old Apr 2, 2003 | 10:31 PM
WiggiE's Avatar
New User
Atlanta, GA
Old Apr 3, 2003 | 07:14 AM
Christian's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (WiggiE)
Thanks Guys,
Those guys @ Baranco Acura Parts are no joke. Absolutely amazing service.
I should be getting my Synchro's tomorrow. We'll let you know
Old Apr 3, 2003 | 07:25 AM
AssPenny's Avatar
Should look something like this
Pretty simple job, took us about an hour or so to swap the syncros on the main & counter shaft. We cleaned everything with laquor thinner first, then diped the parts in a MTF bath and put it all back together. Just fyi, it won't shift to smooth dry, once there is fluid in and your drive it a few miles, it will be like brand new
Old Apr 3, 2003 | 07:29 AM
Chris N's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (AssPenny)
How much does the full synchro set run?
acura_typer's Avatar
Banned
if you are replacing the sycnros, should replace the syncro hub at the same time. Hope thats not the 'gear' you were talking about
Texas HybridGarage Forum Now open
My Dyno
Old Apr 3, 2003 | 07:31 AM
JBBNJ609's Avatar
hey , i have 2 questions , first , is there any diff. with the ITR synchros vs. the GSR ones . . . , and 2nd does anyone have any info on how to do it , for a DIY whos pretty good with engines , my 3rd gear one is shot , and so is my 5th and 1st , so any info would be great , thanks
JAY
Old Apr 3, 2003 | 07:51 AM
Christian's Avatar
Thanks Craig, that is what I ordered.
No, I was referring to the actual Gears themselves
Old Apr 3, 2003 | 08:11 AM
Suprdave's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (Chris N)
Alot...mostly 3-4 Syncro set is the one that goes out...
Suprdave
Old Apr 3, 2003 | 08:17 AM
AK94GSR's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (Suprdave)
How hard is it to replace synchros????
what kind of special tools will i need?
Old Apr 3, 2003 | 08:26 AM
Reid's Avatar
Global Moderator
Default Re: ITR Tranny Synchros' w/o the gears (AK94GSR)
No special tools.
A gear puller would make the job easier, but it's not necessary (I've never used one).
Old Apr 3, 2003 | 08:29 AM
AssPenny's Avatar
Not sure if the ITR is the same as the GSR, i'm sure some one knows though.
As for the job, its looks difficult, but it really isn't, just take your time. Getting the case back together is the hardest part I think. We found that if you get the case on and close, then wiggle the shift linkage, it will align the forks and the case "should" drop down into place. Make sure the top retrainer is pushed back and the openings are visable via the access plug. We use 2 flat head screw drivers to open this clip, some people use a special tool (forgot the name). Also when you take the old gears off, simply place them down in the order you take them off so you don't mess it all up and have to figure out how they go on from the helms. We did this once, and it was a bitch getting it all back, but not impossible.
Tools you will need:
- standard metric socket set
- vice is key although we've done it with out one. I bought one saturday before we did the tranny and it was a major time saver
- 3 prong gear puller
- torque wrench
- scraper to scrap off all the old honda bond
Make sure you have honda-bond, as it will be needed to seal the case back together.
Thats about it, just make sure you take your time and don't rush it. Nothing suck more then putting everything back on the car and finding out it does not work and you have to drop the tranny again.
Old Apr 3, 2003 | 08:33 AM
Reid's Avatar
Global Moderator
The only difference is the gears and LSD. Everything is interchangeable between the two.
Old Apr 3, 2003 | 08:37 AM
DarthLuder's Avatar
New User
Thanks Guys,
werd
Old Apr 3, 2003 | 01:57 PM
JBBNJ609's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (Reid)
yea i was hoping the ITR ones would be stronger/ better , o well , im prob gonna do this soon if some honda smarts' would come over , i will pay , and beer for anyone who comes , i have a car hold( couldnt spell) and lots o jacks . ... o well . ..
Old Apr 20, 2004 | 11:34 PM
Extreme's Avatar
Is there any way possible to show all the necessary part nos?
Old Apr 21, 2004 | 01:01 AM
B2FiNiTY's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (Extreme)
Which part numbers do you need?
http://www.acuraparts247.com
It really does seem intimidating the first time you are doing it but after doing mine, I know the tranny inside out.
Old Apr 21, 2004 | 02:23 AM
strepto's Avatar
Default Re: ITR Tranny Synchros' w/o the gears (B2FiNiTY)
Yeah, B2, I feel you. I gotta tell you, the tranny looks like a scary piece of hardware. Easy to fck. up..
When dropping the tranny, what parts should be replaced? All bearings, diff, syncros... what else?
Old Apr 21, 2004 | 07:13 PM
Extreme's Avatar
Thankyou Sir!
Old Apr 25, 2004 | 10:44 PM
strepto's Avatar
Id really like the part numbers for all the parts needed for a tranny rebuild..
Old Apr 29, 2004 | 08:50 PM
Finland's Avatar
Hey, if you could post a complete parts list, or your invoice, that would be wonderful....I need a set of synchros, but a buddy works at he Honda dealership, so all I need is part numbers and voila...I guess I could do the footwork, but if you have them...
Old Apr 30, 2004 | 05:49 AM
rs's Avatar
rs
Default Re: ITR Tranny Synchros' w/o the gears (boost psycho)
I need to do my tranny when I get back to Tampa. Never done it before, so I need the part numbers as well. I know they are in the Helms, but still a little unsure.
How long does the complete job take. From start to finish, including dropping the tranny?
I'm iching to get back to Sebring, but can't until my syncros are replaced.
