how to remove tint
Old Apr 2, 2003 | 06:38 PM
Superdragr45's Avatar
Default how to remove tint
anyone kno how to remove tint, or should i just go to a professional and have them do it???
Old Apr 2, 2003 | 07:34 PM
BigChris's Avatar
Default Re: how to remove tint (Superdragr45)
get some windex and a raizor blade...
put your window down halfway so you can start taking the tint off the top of the window
what you do is spray the top with alot of windex to make it moist and slow stick the raizor into the film. you should be able to see the line where the tint stops.. thats where you wanna start taking it off from... slowly but surely you work your way down.. its kind of time consuming but definitely saves u money DIY.
Old Apr 2, 2003 | 07:56 PM
jokerstud's Avatar
Default Re: how to remove tint (BigChris)
what i did that was a bitch but it worked was just find where it starts, and rip the whole sheet off and then went at all of the sticky stuff with one of those window widgets. getting off all the sticky stuff was a pain so if you can use windex like this guy said and it comes off all at once, thats much better
Old Apr 2, 2003 | 08:06 PM
iam7head's Avatar
Default Re: how to remove tint (jokerstud)
you going to hate yourself when you scratch some defroster/ antenna
the shop i got my tint from charge like 45 bucks for tint removal for sedan
Old Apr 2, 2003 | 11:17 PM
patastinky's Avatar
Default Re: how to remove tint (iam7head)
soapy water that's it!! .. that's how i took off my tints..
but the best way that i found it (more time consuming) is heat gun. . just heat the window up .. and peal the tint away .. the glue and everything will come off in one shot.. no need to take a razor to the window after removing the tint (because the glue comes off on the tint as you heat it up and pull it off)
Goodluck!
Old Apr 3, 2003 | 04:12 AM
m0t0rhead's Avatar
buy a heat gun.
Old Apr 3, 2003 | 05:48 AM
dcaccord's Avatar
funny that you posted this, as i just impulsively ripped my tint off last night. Here's the deal: if you can get your hands on some acetone, put some on a rag. It wipes the glue right off with minimal effort. my wife works at a lab so it is easy for me to get. Otherwise you can use nail polish remover. Just make sure you wash the inside of your windowsa good afterward.
Old Apr 3, 2003 | 08:15 AM
boonacka's Avatar
Default Re: how to remove tint (dcaccord)
does that heat gun and acetone trick work for the rear window with defroster as well?
Old Apr 3, 2003 | 11:51 AM
crafty's Avatar
Default Re: how to remove tint (boonacka)
i bet it might be less of a hassle to just buy a new back window!
anyone know how much that'll cost?
i scraped all the defroster lines off
Old Apr 3, 2003 | 09:27 PM
iam7head's Avatar
Default Re: how to remove tint (crafty)
lol i actually know a guy who replace his rear window because of the bubble
Old Apr 3, 2003 | 10:01 PM
Heat's Avatar
I called a customizing shop today just to see how much tint would cost to install. For my '99 sedan, $150 for the back seat windows and the rear window (it's illegal in Illinois to tint the front side windows). I asked how much to take it off, he said ~ $100 if I didn't mind losing the defroster, and $200 if I wanted to keep the defroster.
I'm seriously considering the Honda sunshade (which is a rollup white sunshade) for $75, I'm just not sure how it will look.
iam7head, what bubble caused the guy you know to replace his window?
[Modified by Heat, 7:03 AM 4/4/2003]
Old Apr 3, 2003 | 10:03 PM
iam7head's Avatar
Default Re: how to remove tint (Heat)
well he got the imfamous purple 2 pieces tint on his car.
the shop i tinted mine quote for 45-50 for tint removal, prolly more for sedan
Old Apr 3, 2003 | 10:05 PM
iam7head's Avatar
heat, i read your post too..just tint it with a good shop, the sun shade thing is for grandpa's CLK imo
life time warranty is a wise thing to have too i guess..although claiming it will be pita
Old Apr 4, 2003 | 11:32 AM
crafty's Avatar
thats what i scraped off when i got my accord...hence no more defroster
I heard they make some sort of replacement if you scrape that stuff off...like just re-apply some sort of strip?
can anyone confirm this???
Old Apr 4, 2003 | 11:53 AM
Heat's Avatar
You live in LA, do you really need a rear windshield defroster?
Old Apr 4, 2003 | 11:58 AM
accord91h22's Avatar
I used finger nail polish remover. Worked like a charm!
Old Apr 5, 2003 | 09:15 AM
crafty's Avatar
good point
but of the few times i've needed it
Old Apr 7, 2003 | 04:18 AM
visual's Avatar
can i use a hair dryer instead of a heatgun ?
Old Apr 8, 2003 | 11:57 AM
crafty's Avatar
Default Re: how to remove tint (visualvb)
I've tried the hair dryer on my friends car....
Mind you I have no expertise about hair dryers so I dont know if some actually get hotter than others but i sat there until my arm felt numb and it didnt work....
it peeled off without the glue
i recommend getting a heat gun or renting one from home depot
Old Apr 8, 2003 | 01:15 PM
Nite's Avatar
I pulled mine off, and used a razor blade combine with paint thinner it worked like a charm...cept i didnt do the back windows so i dont know what to tell you abotu doin the back
Heat... that is fuken expensive for window tinting/removal. I would definatly shop around. Ask some guys who are in the car business. I found out an hour after i got mine done when i went to the muffler shop that there was a guy across the street that would do it for 100 bucks. Id definatly shop around
Old Apr 8, 2003 | 03:07 PM
ichibanjap's Avatar
Default Re: how to remove tint (Nite)
For the back window on mine, i used the green scotch brites and soapy water. Worked fine for me.
Old Apr 8, 2003 | 03:12 PM
aux's Avatar
aux
i went to Diamond Tint here in san diego and got the rear and sides done for 65 total.
Old Apr 8, 2003 | 08:53 PM
crafty's Avatar
Default Re: how to remove tint (ichibanjap)
damn i wish i would've known or thought of that
djessenz
90
Feb 22, 2012 02:53 PM
accord99power
Dec 12, 2008 08:35 AM
athoughts
Nov 28, 2005 04:47 PM
alfaaay
Aug 2, 2003 05:56 PM
gokuson
Jun 21, 2002 01:24 PM
