Help!! got flatbedded home
I was driving yesterday and my car started to sputter and then stalled when i came to a stop sign. It took a bit to turn over, I let it sit and idle(which was fine) When i pushed down the gas I kept on getting sputtering untill about 3k then it would rev fine. It seems like not enough fuel, or too much air, no spark, vacum? I have new wires (msd) and plugs (bosch +4) and a new fuel filter. What else could it be? I never changed the timing and I did replace the belt. No extreme motor work. Just started happening.
i says its probably the coil or ignitor in the distributor...i say test to see if your getting any spark..if you are then check to see if your getting fuel
Its not throwing any codes, dont know if obd1 has anything to do with it. My boy said something about an air idel control valve, I never heard of it. Should i check my compression? Thanks for the help
I seen real life situations with timing, the car does the exact same **** you just said. Have it checked by the people who installed your belt.
johnny090881
Jun 7, 2009 10:56 PM
manintux
Jul 7, 2008 05:52 PM
the soL that could
11
May 30, 2006 07:58 AM
