type r head??
alright, how can i identify a USDM type R head. i know there has to be the green paint behind the distributor, but what are other ways (without taking off the valve cover).
thanks,
by the way i searched but search is sucking *****
thanks,
gsr says p72 and type r says p30
p30 is also b16
but the type r head has slight port work just to compansate for the bigger valves
[Modified by racerboyb18c1, 2:22 AM 4/3/2003]
p30 is also b16
ITR valves are not bigger.
The head itself is simply rebowled.
p30 is also b16
p30 is also b16
rebowled?
bowl of the ports is nicly blended into the valve seat area. long and short turn of the ports are untouched.
rebowled?
Mild porting at best.
I have similar pics of the work, from the intake ports.
You can also tell by popping out 1 of the valve's. I learned this from Cheetah.
The b16 valve has a straight design. Where as the type-r valve has a little notch on the valve. Look at the pic below.
The green Paint Just means it is a Replacment Part
Edit: including mine..
[Modified by Nameless EJ6, 10:03 PM 4/2/2003]
5thgen4dr
Sep 27, 2007 09:31 AM
MotorMatrix.com
Mar 3, 2003 11:53 PM
