Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Trans & Brake Fluid volume
Old Apr 2, 2003 | 12:01 PM
Shmeek's Avatar
Default Trans & Brake Fluid volume
Sorry to post this here, but it's the only true board on HT. The others would tell me about the new lightup tail pipe and glow in the dark brake fluid.
For a '98 GSR, anyone know off the top of their head how much fluid I need to flush the brake system and change the manual transmission fluid? Don't keep the Helms manual here at work, and really should order fluids TODAY!
Old Apr 2, 2003 | 12:31 PM
bb6h22a's Avatar
Default Re: Trans & Brake Fluid volume (Shmeek)
2 bottle of honda MTF for just a drain & fill
3 bottles of Honda brake fluid for a flush (err on the side of caution.)
Old Apr 2, 2003 | 12:53 PM
Crack Monkey's Avatar
I *think* it's 4 qts of fluid for the tranny.
You fill it until the fluid reaches the fill hole.
[Modified by Crack Monkey, 1:54 PM 4/2/2003]
Old Apr 2, 2003 | 12:57 PM
Mike P.'s Avatar
25 Year Member
On my B16 transmission, I have twice used just over 2 quarts to fill it, so I normally buy 3.
Brake flush can be iffy, depending on how much trouble you have getting all the air out of the system. Sometimes the bubbles get trapped in the caliper. I've used almost 2 liters once on an especially troublesome brake bleed. The stuff is cheap, so may as well buy extra.
Old Apr 2, 2003 | 02:18 PM
.RJ's Avatar
.RJ
2.3qts MTF
Buy 2 liters of brake fluid just in case, depends on how good you are with it. I can flush a system with 1/2-2/3 of a bottle.
RJ
GailATL
Honda Civic (2016 - Current)
Jan 29, 2019 04:33 PM
Guimba
Suspension & Brakes
Feb 17, 2010 06:05 PM
SilverDc2
Jun 6, 2004 08:54 PM
Flux
Oct 8, 2001 10:00 AM
Floyd
Sep 14, 2001 11:56 AM
