Quick, which wire is the primary o2 sensor wire needed for an A/F gauge?
Which wire going to the ECU do I use? This is on a '98 GS, i think it's the all white wire, but i'm not sure. Help quick, i wanna get this down, TIA.
i checked helms and is says the GREEN wire is PSPSW (P/S OIL PRESSURE SWITCH).
It says the WHITE wire is PHO2S (PRIMARY HEATED OXYGEN SENSOR): Detects primary 02 Sensor signal. With throttle fully opened, fully warmed up engine: above 0.6V With throttle quickly closed: below 0.4V. Does that sound right, or should it be something else?
JusT a Cx
Apr 26, 2004 06:46 PM
