Compression Test Numbers For my 98 LS
Cylinders:
1: 152 2: 150 3: 150 4: 150
Are these numbers low for my LS?? I'm worried because i'm going to be boosting soon, and didn't want to **** anything up.
Cool, I wasn't too sure what would be too low. If you have high milage on your car, there might be carbon deposits that up the compression naturally
Cylinders:
Stock LS compression: 200
Minimum:135
Cylinders:
Cylinders:
It should also make a difference what gauge you used. It's only really fair to compare the actual pressure numbers if different engines were measured with the same gauge. The internal volume of the gauge makes a difference.
If somebody told you that your engine had 220psi numbers when it was new, now its only 185psi, you'd probably worry. But that's only fair if they were measured with the same gauge.
What about if my battery was dying throughout the test. I had to charge my battery through my friends car, while we were doing it.
integranator
Apr 2, 2003 11:34 AM
