Anyone know what size pistons (Bore/stroke) come in a 89 Teg?
Old Apr 2, 2003 | 10:35 AM
ZColeon's Avatar
New User
Default Anyone know what size pistons (Bore/stroke) come in a 89 Teg?
Someone told me that they thought they were same as a d16a6 -75x90
But have a higher compression ratio than the A6's 9.0-1?
Thanks for the insight..
Old Apr 2, 2003 | 11:25 AM
keithv's Avatar
Default Re: Anyone know what size pistons (Bore/stroke) come in a 89 Teg? (ZColeon)
everything you were told is true.
Old Apr 2, 2003 | 11:36 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
p29: (88-89 d16a1)
piston to deck clearance = 0.040"
dish/dome volume = 7.2cc
pm6: (88-91 d16a6)
piston to deck clearance = 0.020"
dish/dome volume = -3.4cc
Old Apr 2, 2003 | 11:40 AM
ZColeon's Avatar
New User
Default Re: Anyone know what size pistons (fastcrxsi90)
Do you know what compression piston comes in these?
I have put 2 sets of 9.5-1 ZC pistons in the D16a6, and wow what a difference, Curious if I should look for the teg.
I Take it the d16a6 Teg has the same 9.0-1 pistons?
I thought the 88-89 teg came with the D16A8/9 ; The DOHC non-Vtec usdm motor?
Old Apr 2, 2003 | 11:50 AM
keithv's Avatar
Default Re: Anyone know what size pistons (ZColeon)
the 88-89 teg is a d16a1.
the zc pistons are the same as the 88-89 USDM teg pistons.
Old Apr 3, 2003 | 04:15 AM
ZColeon's Avatar
New User
Default Re: Anyone know what size pistons (breaka_1_9)
Dose anyone know if the teg pistons are 9.5-1 or 9.0-1?
Old Apr 3, 2003 | 04:28 AM
keithv's Avatar
the 88-89 integra is 9.5:1 compression. when you put those pistons in a different block with a different head, the compression ratio will change.
Old Apr 3, 2003 | 07:55 AM
ZColeon's Avatar
New User
Thanks Bro...
Sonny
36
Apr 11, 2007 04:54 PM
Import RP
Feb 4, 2005 11:32 AM
89civichatchback
May 2, 2003 12:43 PM
a6withnuts
Jul 28, 2002 01:41 PM
