vtec solenoid gasket?
Old Apr 2, 2003 | 08:39 AM
type Gendy's Avatar
Default vtec solenoid gasket?
Oil leaking down my motor (B16a) , coming from the vtec solenoid... What gasket (o-ring) to replace, and what should i order it for....
Old Apr 2, 2003 | 10:03 AM
rustycivic's Avatar
Default Re: vtec solenoid gasket? (sick hatchem)
if its a b16a1 solenoid its a bastard gasket...new gaskets from honda will not fit right..I dont know if any else has had this problem, but when I ordered new gaskets for my solenoid from honda they didnt fit right and still leaked like a ****!
Old Apr 2, 2003 | 10:05 AM
Adam F's Avatar
all Honda Acura VTEC solenoid are the same.
Old Apr 2, 2003 | 10:20 AM
EE9's Avatar
EE9
Default Re: vtec solenoid gasket? (Proelite103)
15825-pr3-005 is the part number of the VTEC solonoid
np
Old Apr 2, 2003 | 10:37 AM
wuhungsixxx's Avatar
New User
check to make sure its not your cam cap which is directly next to the vtec solinoid...that thing always leaks with age...just replaced it in my b18c1 and b18c the other day with the billet aftermarket ones
Old Apr 2, 2003 | 01:21 PM
type Gendy's Avatar
Default Re: vtec solenoid gasket? (wuhungsixxx)
so they are all the same? Does it matter if i order Del sol b16 or GSR? Should i also order this other gasket ? ARe they a bastard to change?
Old Apr 2, 2003 | 01:50 PM
New User
easy....just dont torqe the bolts too much...if you break em then you will really be kicking yourself...need some hondabond or high temp sillicon to put dabs of it here and there when you take off the valve cover...you can tell where you should put it by looking at the old gasket to see where is once was...b16a and b18c should be the same...not sure though
Old Apr 2, 2003 | 02:17 PM
JoshDM's Avatar
you need more than just one gasket
here's the part numbers
15825-P08-005 gasket and filter $14.88 list
36172-P08-015 gasket $6.18 list
91319-PR3-003 o-ring $1.92 list
Master23
17
Apr 1, 2018 08:48 AM
kc_kc
Dec 23, 2010 07:58 AM
Luca
Sep 17, 2009 12:26 PM
bangin4door
Nov 20, 2006 08:47 PM
type Gendy
Apr 2, 2003 01:17 PM
