clutch makes a scraping noise when i let it out ?? why?
it sounds like a piece of metal rubbing on something or a spring being stretched from the clutch area. it just started lately.. what could this be? its a 93 SI hatch.
Squeaking noise, or more of a rubbing sound? It's probably your release bearing (Is that the same as the throw-out bearing?). Common problem, but you have to drop your tranny to replace it. They're only about $10, but if your going to go through the trouble, then you might as well replace the clutch while your in there. Most clutches come with these bearings.
thatdamngood
12
Mar 17, 2004 09:03 PM
Cosworth
Aug 23, 2002 03:02 PM
