200 whp, what is a good clutch for it.
I have an all motor set-up putting close to 200 whp. Would a clutchmaters stage 3 clutch be overkill for this motor? What else would you recommend? Also the clutch to get for a JDM S1 is from a ???
How long have you been running that clutch? Is the engagement rough?
Also what is the difference between a heavy duty clutch and the Xtreme one?
[Modified by ACRXGuy, 10:48 AM 4/2/2003]
I've had the clutch for about 2 years now, she has stock pedal feel, and has worked flawlessly. I think the heavy duty has a little less clamping force than the Xtreme but I would have to refer you to ACT for the official response.
I have the ACT HD Pressure Plate and Street Disk too.......holding in fine at 180whp so far.......can't wait to put it to the test more.
I've driven a GSR w/ 6puck HD pressure plate, and its pleasantly stiffer, and engages hard...the car is only making a mere 165 @ the wheels...but I thought Id add. I like it, but you might want a stonger clutch
derka_si
Jun 30, 2012 08:48 PM
Rhymenoceros
16
Apr 21, 2007 06:42 AM
