No more vibration(H22a setup)
Old Apr 2, 2003 | 04:33 AM
Civic Rs's Avatar
New User
Default No more vibration(H22a setup)
I had bad vibration at ~30 mph like a lot of h22a civic hybrid So I decided to try something to resolve the problem. I have HCP EG kit with better rear bushing than the original one. What I did is shim the rear mount by 1/2 inch with the front hole and 3/8 with the 2 other rear hole of the bracket. Yesterday I test it for the first time and WOW surprise no more vibration The clearance are much better from the firewall and the fan/bleeder in the front. I simply use jack to raise the tranny and insert some shime into the rear bracket I share this information to you and I hope this will help some guys with this ******* problem
Old Apr 2, 2003 | 05:15 AM
Jason kiDD's Avatar
Default Re: No more vibration(H22a setup) (Civic Rs)
Pics??!?
Old Apr 2, 2003 | 05:25 AM
Civic Rs's Avatar
New User
Default Re: No more vibration(H22a setup) (Jason kiDD)
Not yet because I dont have digi cam... but I can take some picture for you this weekend
Old Apr 2, 2003 | 09:04 AM
k_spek's Avatar
Cool. I would like to see pics. I still have bad vibration problems with my hcp kit.
Where did you get a better rear bushing?
[Modified by laugHin22CX, 6:06 PM 4/2/2003]
Old Apr 2, 2003 | 09:30 AM
Jonathan_ED3's Avatar
Default Re: No more vibration(H22a setup) (laugHin22CX)
sounds sweet!
By better bushing, do you mean softer? Or what?
Old Apr 2, 2003 | 11:17 AM
Civic Rs's Avatar
New User
Default Re: No more vibration(H22a setup) (hot_EG)
lol
Some people will laugh for the rear bushing I use I had 2 HCP bushing that last 1 week before they fail, so I decided to used something to hold for a long time I took 3 hockey puck(orange one) and go to machine shop with the size of the bracket.... fill the rear mount with this and polyeurethane to old in place. Since that time no more problem but it`s very stiff when I launch the clutch If you dont have any problem with the HCP rear bushing you dont need to do this. The time I took to raise the rear mount it`s average 45 minutes, beacause the bolt are hard to loose when everything still there. I used 3 big nut, the same size as the hole on the bracket and put it under(you need longer bolt for sure) when the engine is raise with the jack. The one on the front I use 1/2 inch nut and at the rear 3/8 inch each one. For MY setup that work great, I dont know if that can resolve the problem of other H22a hybrid, I hope This weekend try to take some picture if I can.
Old Apr 2, 2003 | 11:25 AM
Newman's Avatar
New User
Same pretty much applies to EF B-series swaps also. If you bend the lip on the rear subframe, giving more clearance for the mount and bracket, then nothing will touch and there will be no vibration. Vibration usually comes from the mount or bracket touching something else on the car, thus causing the whole thing to shake.
Old Apr 2, 2003 | 11:29 AM
Jason kiDD's Avatar
What year is your engine by chance?
Old Apr 2, 2003 | 03:23 PM
Civic Rs's Avatar
New User
Default Re: No more vibration(H22a setup) (Newman)
Nop nothing was touching the car the vibration came from the axle when accelerating(around 30 mph like a lot of people here I think). Just change the angle and that make the difference between vibration and nothing I just share the information that work for me so if that can help someone else that good For my engine 94 JDM
[Modified by Civic Rs, 12:25 AM 4/3/2003]
Old Apr 2, 2003 | 03:36 PM
k_spek's Avatar
What axle setup are you running again civic rs?
Old Apr 2, 2003 | 04:42 PM
cccya's Avatar
good job. now its my turn.. hope my new rear tranny mount and new tranny bracket, will fix the problem.
good job for you
Old Apr 2, 2003 | 04:56 PM
Civic Rs's Avatar
New User
Teg 86-89 both side with 1.8 drop in the front.
GEIJIN
Oct 8, 2006 11:21 PM
Redline130
Dec 13, 2005 01:36 PM
gambo117
Mar 6, 2004 06:32 PM
H22A EG6
Feb 4, 2004 03:29 PM
Risingsun
Jan 10, 2004 10:38 AM
