Grounding wire?
Old Apr 1, 2003 | 06:31 PM
Turbo Powa's Avatar
Default Grounding wire?
What gauge wire can I use to make new ground wires? I can use speaker wires right? Is 12 gauge wire ok?
Old Apr 1, 2003 | 06:48 PM
rainmanEK's Avatar
big strong guy
Default Re: Grounding wire? (Panda EK)
Yes!
Though if you can, Try for somthing little thicker!
Eric
Old Apr 1, 2003 | 06:55 PM
Turbo Powa's Avatar
Default Re: Grounding wire? (rainmanEK)
I also see people using 8 gauge wire. Which is better? Thicker wire?
Old Apr 1, 2003 | 08:21 PM
T3's Avatar
T3
I have a 1200rms amp and Im using 8awg...It all depends on the power of the amp and how much juice it will take..Im using 4awg for the bat and 12awg for the speakers.
Old Apr 2, 2003 | 09:50 PM
bryan305's Avatar
Default Re: Grounding wire? (T3)
Use at least a 4 gauge for the battery ground and 10 gauge for other stock grounds.
I replaced all my ground wires with 4 gauge. Not that expensive.
Wazup
Apr 18, 2011 04:04 PM
bopbop93030
Audio / Security / Video
May 13, 2009 07:35 AM
iinvazionii
Apr 11, 2007 08:56 PM
potatostix
Mar 30, 2006 10:02 PM
mrlegoman
Feb 3, 2003 04:15 PM
