Where do you guys mount your gauges????
I don't want to put it in the A-pillar, thinking of putting it underneath the stock CD player location, does anyone have pic of this setup?
or any other interesting area to mount these gauges?
oh, it's just a regular 2" auto meter A/F ratio and volt meter.......
Thanks
PS> just make a template for the gauges, trying to make something out of aluminum.......as you can tell, it's not the correct size yet, but you get the idea
[Modified by DB8, 7:16 PM 4/1/2003]
[Modified by DB8, 7:17 PM 4/1/2003]
Thanks
You can mount 1 gauge where the "dead" plug is (cruise control button), and the other in place of your dash light adjustment ****. Autometer makes the 2 pod bezel that mounts under the cowl of your dash.
Just curious, why did you select an a/f gauge and a voltmeter gauge? These are kind of unusual selections.
i thought about mounting the gauages where the dead plug and the dimmer switch are, but i will most likey put the JDM fog light switch there, and keep the dimmer, anyway, i got these gauges off a friend who just sold his car, pretty much got it next to nothing.........that's why, and yes, it's not too functional
What I did was...
I picked up a JDM Stereo Block off plate, however i kept the stereo in its original location. Remove the under tray of the stereo, remove ashtray/lighter assembly. I mounted the block off plate underneat the stereo all the way down to where the cup holders are. You will need to modify the block off plate at the lower right side to make it fit since the console curves a little. I dont have pics of the setup quite yet, because its not ready, still havnt put the holes in the tray to mount the gauges, but as soon as i do ill have some pics.
italstallion
24
Jan 8, 2007 08:49 PM
KCHybrid
Jan 7, 2003 10:22 AM
