will not rev past 3 grand b16 swap
Old Apr 1, 2003 | 05:56 PM
dropd4door's Avatar
Default will not rev past 3 grand b16 swap
i just finished putting a first gen b16 into my 89 crx dx... did all the mpfi stuff.. now she will not rev past 3k... it back fires really loud too at 3 grand... anyone got any ideas...
Old Apr 1, 2003 | 06:02 PM
pokemon's Avatar
Default Re: will not rev past 3 grand b16 swap (jdm_crx_vtec)
switch the CPS ( crank position sensor ) wires around, or make sure you took out the DX computer. ;x
Old Apr 1, 2003 | 06:03 PM
dropd4door's Avatar
Default Re: will not rev past 3 grand b16 swap (pokemon)
LOL yeah the dx ecu is out i'm not that dumb
Old Apr 1, 2003 | 06:25 PM
customx_'s Avatar
New User
check knock sensor
are you throwing CEL?
Old Apr 1, 2003 | 06:49 PM
dropd4door's Avatar
Default Re: will not rev past 3 grand b16 swap (usdmRob)
yeah its is... code 4
Old Apr 1, 2003 | 09:38 PM
90civichbsi's Avatar
had the same prob in mine... the ignition was cutting out, turns out Hmotorsonline sent the motor on the ecu messing it up...
just do a quick check by puttin the dx ecu in and see if it revs past 3k.. just a thought
Old Apr 1, 2003 | 09:58 PM
Adam F's Avatar
what ECU?
Old Apr 2, 2003 | 04:51 AM
white99gsr's Avatar
Default Re: will not rev past 3 grand b16 swap (Proelite103)
Mine is doing that exact same thing too. Yes, anyone please help.
Old Apr 2, 2003 | 04:58 AM
madman13lm's Avatar
Default Re: will not rev past 3 grand b16 swap (white99gsr)
I had the same problem and all I did was pull the battery to recharge it and when I put it back in the ECU had reset and it was fine. Of course, it could have been the battery causing the problem. ehh, give it a try.
Old Apr 2, 2003 | 05:28 AM
cyberx's Avatar
Default Re: will not rev past 3 grand b16 swap (madman13lm)
is the battery on backwords, also make sure that the ECU is not messed up, find out by trying out b16a ecu from someone else. also make sure all the sensors are connected....
Old Apr 2, 2003 | 07:30 AM
Rob!'s Avatar
Default Re: will not rev past 3 grand b16 swap (cyberx)
im right in your area if you need an ecu to try out. i got a pr3 pm me if u want
blackwidow_prin
Aug 18, 2011 05:24 PM
hedtrip
May 9, 2006 06:30 PM
skaterdx
Aug 26, 2004 11:11 PM
Lightning Lover.
Nov 18, 2003 12:27 PM
dropd4door
Apr 5, 2003 03:27 AM
