HELP: Stripped Rotor Screw
Old Apr 1, 2003 | 05:21 PM
Flux's Avatar
Default HELP: Stripped Rotor Screw
Well, I was able to get all the rotor screws out with an impact driver without a problem except one. A front screw is completely stripped, how do I get this thing out now?
Old Apr 1, 2003 | 05:24 PM
Reid's Avatar
Global Moderator
Default Re: HELP: Stripped Rotor Screw (Flux)
Try cutting into the screw with a Dremel, so that you may use a flat head screwdriver to remove it.
Old Apr 1, 2003 | 05:33 PM
SpoonEK2's Avatar
Default Re: HELP: Stripped Rotor Screw (Reid)
You could also drill it out.
Rob :190:'s Avatar
just drill it out, they're for stunnas....
Old Apr 1, 2003 | 05:37 PM
Flux's Avatar
Default Re: HELP: Stripped Rotor Screw (Rob :190:)
Ok, this is going to make me sound like an idiot (won't be the first time I guess). How exactly do you go about drilling out a screw?
p.s. I know you use a drill somehow...
Old Apr 1, 2003 | 05:40 PM
lanceh's Avatar
25 Year Member
use a fairly small bit and drill right into the center making sure not to go deeper than the length of the screw. keep increasing the size of the bit until the screw just falls apart.
Old Apr 1, 2003 | 05:41 PM
Flux's Avatar
Default Re: HELP: Stripped Rotor Screw (lanceh)
thanks...
Old Apr 1, 2003 | 06:22 PM
GRM Scott's Avatar
25 Year Member
an easier method that worked for me: I got a drillbit that was a bit wider than the diameter of the shaft of the screw, and drilled until the head seperated from the body. To my surprise, i was able to hand-remove the threaded remainder of the shaft, all of the stubbornness had been the head of the screw where it was hitting the disc hat. Don't have to go as deep drill-wise this way, and if you can't get the old one out, who cares.
Old Apr 1, 2003 | 07:05 PM
Dr Pooface's Avatar
Default Re: HELP: Stripped Rotor Screw (Aleph)
Do what Aleph says. It is much easier. After you drill the head off you can just leave the body of the screw in the hub, if you want.
Old Apr 1, 2003 | 07:13 PM
Mugen Mike's Avatar
Default Re: HELP: Stripped Rotor Screw (Dr Pooface)
Or you could replace them with the lightweight Spoon ones
Old Apr 1, 2003 | 07:15 PM
B2FiNiTY's Avatar
Use a size larger with impact wrench Worked for me and spoon *****
Old Apr 1, 2003 | 07:25 PM
Flux's Avatar
Default Re: HELP: Stripped Rotor Screw (B2FiNiTY)
The screw has been extracted. We can all sleep in peace tonight..
Old Apr 1, 2003 | 07:35 PM
sackdz's Avatar
God must be listening. I said prayers for your rotor tonight.
Old Apr 1, 2003 | 07:44 PM
Chris N's Avatar
Default Re: HELP: Stripped Rotor Screw (sackdz)
I'm going to sleep much better now.
Chris - who also wanted to know what 'just drill it out' meant.
OEMaccord
Jun 3, 2024 09:06 PM
msinsky14
Nov 23, 2006 04:26 PM
toguemaster
Suspension & Brakes
May 27, 2006 01:25 PM
honda99 front rotors
Sep 11, 2005 03:51 PM
SurferX
Jan 24, 2003 08:31 PM
