Ls type r head swap info??
Old Apr 1, 2003 | 02:59 PM
typerspoon's Avatar
Default Ls type r head swap info??
On my integra ls I wanted to do a vtec type r head swap. The head will be complete and have all the tricks done to it ( port polish, cams, valve spring retainers etc....) I just wanted to see if anyone else could recommend something else I would need to make the swap better. Like if I need new injectors, water pump etc... thanks
Old Apr 1, 2003 | 06:53 PM
TimoneX's Avatar
New User
Default Re: Ls type r head swap info?? (typerspoon)
I'd worry more about the oil pump.
Old Apr 1, 2003 | 08:47 PM
vtec69's Avatar
Default Re: Ls type r head swap info?? (TimoneX)
yeah go with the vtec wp, vtec oil pump, and vtec ecu preferely a chipped p28
Old Apr 1, 2003 | 09:49 PM
Big_Mike's Avatar
get some 330cc injectors, you will increase your power 10%
Old Apr 3, 2003 | 01:02 PM
typerspoon's Avatar
Hey thanks guys, any more info would be great I'm trying to make something with good power, reliability etc..... Is the type r head the best choice, or should I go with some other vtec head. Also would a jdm type r ecu be ok?
Old Apr 3, 2003 | 01:10 PM
typerspoon's Avatar
Does anyone have a type r water pump, oil pump, ecu and injectors for sale?
Old Apr 4, 2003 | 09:59 AM
TimoneX's Avatar
New User
The Type R head is the best one stock. I'd take a properly ported B16 or GSR head over a Type R head however. If you're going to have it ported by someone experienced with doing Honda head work then just snag a B16 or B18C head.
92teggyLS
Sep 11, 2008 11:27 AM
albertleee
Oct 9, 2007 09:33 AM
ThatOneOG
Jan 12, 2006 01:16 PM
4drBlankito2.0
Feb 13, 2004 12:05 AM
