ITR header on B16EG hatch???
Will the ITR header fit on my EG6. It's the one with the stock B16A2 engine..??
I am planning on buying a Supersprint ITR performance header, because it's just a little bit bigger than the one they make for the B16.. and it's just a little to small I was told...
Thanks....
M. Nielsen, Denmark
Thanks....
M. Nielsen, Denmark
Yes and no.
It will bolt up fine, no need to worry about that.
But you need to take into consideration two things.
1. It hangs a little bit lower than a stock B16 manifold. So, you can't be lowered too much.
2. It has a 2.5" collector. So, you'll need to modify or replace your cat with something that will work.
Hmmm... my car is lowered pretty much... and the cat shouldnt be a problem, because I am buying a replacement cat without flanges (??) so it will be costum made for the header...
