Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
New tires rub steering upright, do I grind?
Old Apr 1, 2003 | 01:40 PM
Eee Pee's Avatar
Default New tires rub steering upright, do I grind?
New Hoosier 20x9.5x13 slicks. Cantilever sidewall.
Mounted on a 13x7. Backspace is 5 inches.
I measured more than a few times, but missed it by that much....
It just barely rubs. Almost not at all. The new pointy things do, and the sidewall does, but barely . BARELY!
It still spins fairly freely, but I can hear it slightly.
I'd rather not run a spacer for obvious reasons...No return on the wheels as they where custom made Diamonds (~$65).
Can the sidewall take a little rubbing?
Should I grind the teeny tiny bit off the upright?
The rears used to rub the trailing arm some, so I may be good.
I was looking for some opinions.
Old Apr 1, 2003 | 02:21 PM
Warren's Avatar
Wrong-Way Wang
Default Re: New tires rub steering upright, do I grind? (Eee Pee)
If they rub in a straight line, they'll rub like hell in corners.
Warren
Old Apr 1, 2003 | 06:28 PM
smokin rubber's Avatar
Where did you buy the slicks, and how much were they? And how do I convert liters to cc's?
Old Apr 1, 2003 | 06:46 PM
CRX Lee's Avatar
I'd think real hard about running some thin spacers. I have 19mm hub centric spacers on my F Prod car to keep my slicks about 3/8 inch away from my upright at the top. Obviously scrib steer will be effected but you won't have to run as much spacer as I do. The bolt plate on the Diamond wheels should be pretty thin so I'd think you'd still be all right on the stud length.
Old Apr 1, 2003 | 07:47 PM
Eee Pee's Avatar
Default Re: New tires rub steering upright, do I grind? (CRX Lee)
Two years ago I ran 20x8 all around and they fit with a 5" backspace.
I measured the cantilever sidewall of those and the 20x9.5s. They measured the same mounted, so I don't know what happen. Last year I ran a 4" backspace, which was really the wrong backspace, they stuck out, they scrubbed funny, they really changed the whole front end geometry. So I tried a 5"...
I have the cheap Jeg's 1/4" spacers...I just didn't want to use them.
I probably will. As grinding seems iffy.
Diamonds are lugcentric so that's easy to work with and yes, the
bolt plate is not too thick. Thanks Lee.
Rubber smoker, I bought them from Tom at http://www.Midatlanticmotorsport.com.
Move the decimal point y0! Math forum?
I wish they offered a 4.75" backspace...****!
Edit: pic is upside down.
[Modified by Eee Pee, 12:05 AM 4/2/2003]
Old Apr 1, 2003 | 08:02 PM
manveer's Avatar
Default Re: New tires rub steering upright, do I grind? (smokin rubber)
1 L = 1000cc
Old Apr 1, 2003 | 10:12 PM
DB2-R81's Avatar
25 Year Member
Default Re: New tires rub steering upright, do I grind? (manveer)
20.0 X 8.0-13 section width 9.2"
20.0 X 9.0-13 section width 11.0"
You wrote;
“I measured the cantilever sidewall of those and the 20x9.5s. They measured the same mounted, so I don't know what happen.”
All I can say is you must have measured wrong, not possable for them to be the same width.
Old Apr 2, 2003 | 03:16 AM
Eee Pee's Avatar
Default Re: New tires rub steering upright, do I grind? (DB1-R81)
The wheel lip to edge of sidewall is the same for the two ~1 3/8 inch.
The wider tire sticks out further from the car, as the backspace is the same.
Grinding the suspension metal doesn't seem like the right thing, but
I was curious if anyone has, and if it causes problems. Thanks again.
Edit: too early to spell.
[Modified by Eee Pee, 7:26 AM 4/2/2003]
Old Apr 2, 2003 | 03:37 AM
preparedcivic's Avatar
The only solution is to run spacers, with longer wheel studs if needed. Really won't hurt anything, and you'll get the effective backspace dimension needed.
boostedb20z
Apr 14, 2009 05:29 PM
K2e2vin
Nov 16, 2008 12:36 PM
b20integrapower
Feb 23, 2006 02:55 PM
celica73
Apr 2, 2003 05:18 PM
PM-Performance
May 22, 2002 07:12 AM
