Red line for B16a?
Old Apr 1, 2003 | 12:13 PM
B16Anis's Avatar
Default Red line for B16a?
What should a B16a engine redline at ?
Old Apr 1, 2003 | 12:30 PM
plastik462003's Avatar
Default Re: Red line for B16a? (B16Anis)
8 grand i believe
EL Vap133's Avatar
what ECU are you using? Some people say 8200, some say 8k....
Old Apr 1, 2003 | 12:47 PM
zCivic's Avatar
Default Re: Red line for B16a? (Vap133)
exactlly also depends if auto or m/t ECU autos have a lower rev limit.
Old Apr 1, 2003 | 12:48 PM
Mr Furball's Avatar
Default Re: Red line for B16a? (zCivic)
from the factory is 8000
Old Apr 1, 2003 | 01:17 PM
B16Anis's Avatar
88 CRX Si ECU
Old Apr 1, 2003 | 01:22 PM
mbsi's Avatar
for that crx ecu your vtec won't be working and I believe the rev limiter is 6500 rpm on that ecu
Old Apr 1, 2003 | 01:44 PM
B16Anis's Avatar
Default Re: Red line for B16a? (mbsi)
Well I know I got the vtec, it screams Not to mention the V-AFC shows it. 6500 for rev limiter? That's way too low
Old Apr 1, 2003 | 03:36 PM
zCivic's Avatar
ok you have V-tec because your running a V-AFC to activate V-tec, the rev limit on a SI ecu is 6500 cold and 6800 warm, you dont have a B16 ECU if your rev limit is below 8k with no CEL, now if you have a CEL the rev limit would still be 7200 RPM's
98greensi
Mar 5, 2012 04:07 PM
bobbo
Apr 28, 2005 02:29 PM
respectblades
Jan 19, 2005 07:14 AM
SOHC Gord
Aug 18, 2004 12:02 PM
Quicker
Sep 27, 2003 09:12 AM
