Removing Crank Bolt
Old Apr 1, 2003 | 08:59 AM
MCP486's Avatar
Default Removing Crank Bolt
I need to remove the crank pulley so I can remove the timing belt...I have tried a whole bunch of things, Snap-On Impact Wrench, soak bolt in WD-40, use heat gun. Any tips for getting it off? It's on there really tight.
Thanks,
Matt
Old Apr 1, 2003 | 09:07 AM
The Toecutter's Avatar
Default Re: Removing Crank Bolt (MCP486)
500-600 ftlb impact gun or Moroso tool. I've tried the in gear, long *** breaker bar method and ended up just spinning the motor. Some people have had luck wedging something in the flywheel area to prevent it from moving.
Good luck
Old Apr 1, 2003 | 09:12 AM
Willard's Avatar
Honda crank pulley holder + 19mm 'impact' socket + 1/2 brake'er bar + 3' long, piece of 2" I.D. pipe = removed crank pulley bolt.
Old Apr 1, 2003 | 09:31 AM
Suprdave's Avatar
Just hit it with the impact for a couple big tanks of air...
Or use Willard's method, either works...
Suprdave
Old Apr 1, 2003 | 09:46 AM
IN VTEC's Avatar
Default Re: Removing Crank Bolt (Willard)
Same, but I only need a 24" breaker bar to break it loose.
Brace the crankpulley holder on the floor and apply steady and consitent pressure onto the breaker bar.
Old Apr 1, 2003 | 09:48 AM
Willard's Avatar
Default Re: Removing Crank Bolt (IN VTEC)
the piece of the floor jack handle that I use is 3' long.
6_Speed
Aug 18, 2020 06:02 PM
faran
Mar 30, 2010 05:09 AM
NeverOne
May 5, 2007 08:26 PM
judunty84
27
Apr 5, 2007 12:07 PM
Teg_93
Jan 15, 2007 06:55 AM
