Have you guys seen this kinda set-up before.
Old Apr 1, 2003 | 08:28 AM
1.8Tities's Avatar
Default Have you guys seen this kinda set-up before.
Ok, here is the AutoX event I went too last summer and caught a glimpse of this yellow hatch. I was looking at the engine and noticed that the turbo itself is bolt up above the exhaust mani or something. I know majority of the turbo sits under the manifold, but this was kinda sits up a lil higher. I'm just curious about the set-up and if you could enlighten me or something that would be great. I didn't have a chance to talk to the owner cause he was busy taking the cones.
The owner is actually a 40/50 years old mang.
Low enough??
[Modified by 4thGSi, 9:29 AM 4/1/2003]
Old Apr 1, 2003 | 08:33 AM
tegasaurus's Avatar
Default Re: Have you guys seen this kinda set-up before. (4thGSi)
it looks like its a type of manifold where the exhaust flange for the turbo is on a slant to keep the shaving of the block at a minimum. But this guy took the approach of mounting the compressor on the driver side which rather than putting it a little bit below the manifold and closer to the engine, puts it a little higher than the manifold and further from the engine.
i don't know if this has any pros/cons but that seems to be why its above the manifold a little bit, vs the common, slightly below.
-Ryan
EDIT: i can't spell for the life of me today.
[Modified by tegasaurus, 10:36 AM 4/1/2003]
Old Apr 1, 2003 | 08:47 AM
hardcorehonda's Avatar
Default Re: Have you guys seen this kinda set-up before. (tegasaurus)
i think you really need some kind of bracing to keep that turbo from snapping of the manifold.
this is the first d series setup i have seen with the turbo in that place.
Old Apr 1, 2003 | 08:48 AM
FOrSfEd's Avatar
Default Re: Have you guys seen this kinda set-up before. (hardcorehonda)
I like the set up looks pretty good to me, different too.
Old Apr 1, 2003 | 09:11 AM
Suprdave's Avatar
Default Re: Have you guys seen this kinda set-up before. (FOrSfEd)
Saw that car drag-racing once...I think it was throwing down low 14s or something...not bad for street tires and a shitload of camber.
Suprdave
Old Apr 1, 2003 | 09:19 AM
1.8Tities's Avatar
Default Re: Have you guys seen this kinda set-up before. (Suprdave)
Suprdave
Yeah not bad.. If I'm not mistaken he ran that car the Battle of the Imports 2k2 right? Or that was the Route 66 event?
Old Apr 1, 2003 | 09:23 AM
Suprdave's Avatar
I think I saw it run at battle, maybe both...*Shrugs*
It's still not fast though...
Suprdave
Old Apr 1, 2003 | 09:42 AM
Smurfylude's Avatar
I think the Drag Gen 2 Manifolds for the Prelude are like that style
Old Apr 1, 2003 | 07:43 PM
tegasaurus's Avatar
Suprdave
its quick... but not fast
And to whomever said something about bracing i think the turboand manifold would be fine, takinginto consideration the turbo is a t25 or similarly small sized turbo, and the manifold's primaries are not very long and/or extended frlom the motor, so there shouldn't be too much stress.
-Ryan
definatly a nice lil autocross car.
Old Apr 1, 2003 | 07:52 PM
nawoj's Avatar
it seems a little bit too low... your messing with the suspesion geometry there...
and if he has camber issues.....
dont buy the graphics and buy a camber kit.
Old Apr 1, 2003 | 10:18 PM
paulzy's Avatar
Default Re: Have you guys seen this kinda set-up before. (nawoj)
I have seen taht car at route 66....if I remember correctly, it's a stock D16z6 upper manifold with a pipe running up to teh turbo
Old Apr 1, 2003 | 11:05 PM
PrecisionH23a's Avatar
Default Re: Have you guys seen this kinda set-up before. (Sushi X [TCL])
correct. that is how mine sits.
[Modified by GudeH23a, 3:05 AM 4/2/2003]
Old Apr 1, 2003 | 11:44 PM
JDM Steev's Avatar
Default Re: Have you guys seen this kinda set-up before. (GudeH23a)
that eg is SLaMMED!!!
*Boostwerks*
Jul 1, 2007 08:23 PM
REMUS 13
Welding / Fabrication
May 17, 2006 09:25 AM
Un0Turb0-WP
Oct 13, 2004 11:04 PM
phiberoptik
Jun 21, 2004 05:12 PM
torq2k
Nov 27, 2003 10:27 AM
