... diy intercooler piping (charge piping)... what diameter?...
(dunno if this has been asked before or not, but)
... what diameter piping does everyone recommend?... before the intercooler?... after?...
setup (after rebuild):
- T3/60-1 .63 a/r
- JE pistons (81.5mm 9.8:1)
- Eagle rods
- ARP head studs
- ACL bearings
- uberchip
- GE or STR blockguard
- GM 2-bar map sensor
- oem headgasket, oil/water pump, etc
- T3/60-1 .63 a/r
- Eagle rods
- ARP head studs
- ACL bearings
- uberchip
Re: ... diy intercooler piping (93LSivic)
i run 2.25 in. pipes execpt for my charge pipe it's 2.5in. how much boost do you plan on running? if over 20psi you might want to consider the 2.5in. charge pipe.
Re: ... diy intercooler piping (IMPULSE B18C-T)
Re: ... diy intercooler piping (1.8T_EG)
Something like air flow is slowed down, or turbo takes longer to come onto boost cause it has to pressurize that much more space.
Earl can contest to this. He has quoted many of times that certain racers have made 500+ on 2.25 back in the days when air to air was used on race cars.
thelate1
06-19-2006 07:04 PM
