what the difference between the p28 and p72 ecu
Old Apr 1, 2003 | 07:59 AM
u2civic1's Avatar
Default what the difference between the p28 and p72 ecu
i have a gsr swap with obd2 rite now
but i want to go to obd1 are there any difference between these two after i chip with some type or program becuase the p28 is so much cheaper then the p72
Old Apr 1, 2003 | 08:00 AM
sshaikh01's Avatar
Default Re: what the difference between the p28 and p72 ecu (u2civic1)
opps nevermind
[Modified by sshaikh01, 11:02 AM 4/1/2003]
Old Apr 1, 2003 | 08:04 AM
B_CRUZ!'s Avatar
it all depends on the chip. if you use two identical chips on a p72 and a p28, it will run the same. it will run off of the program on the chip.
Old Apr 1, 2003 | 09:07 AM
Kalokohan's Avatar
New User
The P28 is cheaper because it's originally for an SOHC. It has to be chipped to DOHC spec to work on your motor. In the end, the costs are about the same. P28 =$150, chip program = $150 = $300 while OBDI p72's go anywhere from $200-$300.
Old Apr 1, 2003 | 09:17 AM
43MA's Avatar
p28 cant run knock or iab
spend the extra coin and get the p72
Old Apr 1, 2003 | 09:54 AM
B_CRUZ!'s Avatar
Default Re: what the difference between the p28 and p72 ecu (Steady)
who cares? he is chipping it. Knock sensor nor IAB would work anyways. The chip disables it.
I have a chipped p72 and the only real advantage is I can remove the little jumper pin to unchip the ecu and it will run off of the stock ecu program. I only do this when I am running my stock intake manifold.
Jdmlifetyper
Mar 26, 2012 11:35 PM
MOVE OVER
Sep 6, 2007 08:59 AM
ilovejdmhoes23
Jan 20, 2007 11:52 PM
djstain
May 3, 2006 11:16 PM
aF
Jan 29, 2006 08:39 PM
