Timing Belt Question??
Old Jun 19, 2001 | 05:50 AM
Petah's Avatar
Default Timing Belt Question??
Hi, I just installed a set of cams and i aligned the timing belt, timed everything properly, and have also turned the crank couple times by hand to make sure everything is lined up. After the job, i went out for a test drive and didn't notice anything unusual. I have taken it to 8000 rpm a couple of times and everything seemed fine. I guess up to now, my timing belt hasn't slipped yet but my question is, could there be a possibility that it can slip a teeth? I mean after i test dorve it?? Thanks
Old Jun 19, 2001 | 05:53 AM
brinks's Avatar
Default Re: Timing Belt Question?? (eg-six)
I can see why you might be nervous about this, having changed a belt myself recently. if you followed the proper tensioning procedure in the shop manual, then there should be no worries. I assume you measured the deflection after tightening down the tensioner? If you have done all of this, evreything should be ok.
jtwoj1
Jun 5, 2015 08:24 PM
da9h-town
Sep 12, 2010 02:38 PM
Kellindal
Dec 1, 2007 02:20 PM
beany
Mar 29, 2006 05:37 AM
92KillerBee
Apr 12, 2004 01:54 PM
