Will Turbo Supra 550cc injectors work on 96+ Integra GS-R?
I'm thinking of getting some Turbo Supra 550cc injectors for my 96 Integra GS-R Turbo, will they fit/work? Let me know please.
Sharky
Sharky
I believe the MKIV injectors are side feed injectors, so they may not work w/o some customization, correct me if I'm wrong.
The MK3 will work (440cc), but as the above poster said, the MK4 (550cc)ones are side feed. You'll need to somehow find a fuel rail that will work.
The MK3 injectors should be a peak and hold, which means you'll need the resistor box from an EF, or 4 x 10w/10ohm inline resistors, as not to fry your ecu outputs.
BTW, the MK3 units are very close to the DSM injectors that I'm running on my GSR.
<hypa is pleased he's involved in a MK3 engine swap project now>
I dont know about the Supra ones, but you could use 89-91 RX-7 550cc injectors. Another alternative to DSM but with no resistor box needed.
Bottoz
Bottoz
Urban_Balla
Honda Civic (2001 - 2005)
Aug 31, 2007 03:02 PM
