Idle problem
Old Mar 31, 2003 | 11:12 PM
team2n1hatch's Avatar
Default Idle problem
Im having an idle problem...it idles up and down between 1000 and 2000 constant and its annoying...I have been told that it could be my vacuum or my IACV...need to know how to fix it and what exactly im lookin for...can anyone hook me up here????
Old Mar 31, 2003 | 11:17 PM
ThatRicerDaniel's Avatar
Default Re: Idle problem (team2n1hatch)
to check your vacuum try lookin over all the vacuum lines and look for any that might be cut or broken or just missing. secondly try the eacv .. its a valve with 2 coolant lines pluged into the bottom of it and its on the back up your intake manifold. after you change then bleed your coolant system by takin off the radiator cap and letting the car run .. if you wait and put water in then bubbles will come out . just wait untill it stop bubbling. for a new eacv you can use one off pretty much any civic ..
Old Apr 1, 2003 | 04:57 AM
fastcrxsi90's Avatar
From: the asshole of america..., upstate new york, USA
yeah...usually the eacv. if you have a haynes, chiltons, or helms look up how to test the eacv before you change it. i thought that mine was bad and it tested differently than what it was supposed to but the idle went from 1500-700, up and down. it ended up that the idle was just set so high and the dashpot wasnt working correctly. but an eacv is usually cheap in the junkyard...so its worth a try.
Old Apr 1, 2003 | 05:52 AM
Rob!'s Avatar
Default Re: Idle problem (fastcrxsi90)
my idle was off real bad and all i did was fix the vacuum on it and it was fine
Old Apr 1, 2003 | 06:29 AM
guttedEF's Avatar
This was posted up on a *recent* topic on this. Someone posted up this link, and it helped me out tremendously. Good Luck!
http://www.g2ic.com/forums/showthrea...threadid=42969
Old Apr 1, 2003 | 06:37 AM
tpr's Avatar
tpr
Before doing a whole lot of extra work, check and or set the warm idle. This is done by first warming the car up to operating temperature (colling fan will be cycling on and off at idle. Turn all accesories off, disconnect the IACV and set the idle to 750 RPM using the idle air control screw on the top left corner of your throttle body. Turn it clockwise to reduce speed. It is most likely set too high. It's easy to check and has fixed this simptom several times for me!
Old Apr 1, 2003 | 11:47 AM
Default Re: Idle problem (guttedEF)
hey....i appreciate the site and all the tech tips...ive beenin this **** for about a year now and Im tryin to get into all the techinical stuff and things like this throw me off. i have a 91 hatch with a d16z6...sohc vtec motor and this is the motor im having the idle prob with. I noticed that the site you sent was for the b18...will the facts still match u[p location and instruction wise with my motor, or can i assume there will be slightly different outcomes and methods for the same things you have listed? well hit me back with any more tips you got...and thanx again
Old Apr 1, 2003 | 01:59 PM
Is there a site or something I can find out how to test my EACV without buying the book. I know its a must have and all but i got cmi's this week and wanna fix it asap. lemme know
91 Civic HB
d16z6
Team 2n1
Old Apr 2, 2003 | 11:17 AM
Default Thanks Everyone
hey guys, and girl, I just wanted to say thanx again for all your help, and especially for that forum site that gave detailed fix it tips. I fixed my idle prob and now just have to focus on cmi's this weenend. by the way, all the problem was, was the plastic piece in the FICV, it needed to be screwed back down...but thanks just the same.
Old Apr 2, 2003 | 02:29 PM
i got the book .. hit me up.
Old Apr 2, 2003 | 03:32 PM
Ben Ogle's Avatar
Good!!
Ben
Dannyboy94
Feb 20, 2015 09:26 PM
B*Goods*EJ2
May 3, 2010 07:15 PM
aakeobo
Jun 7, 2006 07:58 AM
g2style
Feb 4, 2003 10:09 PM
