do i need longer bolts for my Z SPEED tie bar?
Old Mar 31, 2003 | 10:56 PM
JSJ EG6's Avatar
Default do i need longer bolts for my Z SPEED tie bar?
just pick up a z speed tie bar. would i need longer bolts? cuz when my friend got a benen tie bar it came with new blots and they were longer.
Old Mar 31, 2003 | 11:37 PM
Heinz57's Avatar
Default Re: do i need longer bolts for my Z SPEED tie bar? (TEAM JSJ)
Did you get the bar used or new? cuz from what I know..lower tie bars usually come with new/longer bolts..because when you take the OEM bolt out where the rear LCA-to-the-subframe area is..and place an aftermarket bar there...the width of that area will be wider...so I don't really know how the stock bolt will work...but if you DID buy it new, and it didn't come with new/longer bolts...then give it a try...maybe then it's meant to fit...hope this helps.
Old Apr 1, 2003 | 09:26 AM
JSJ EG6's Avatar
Default Re: do i need longer bolts for my Z SPEED tie bar? (Heinz57)
bought it used
Old Apr 1, 2003 | 09:40 AM
Heinz57's Avatar
then it should've come with longer bolts, yo
Old Apr 1, 2003 | 11:14 AM
euclid's Avatar
just go to autozone or advanced auto parts, ask for suspension grade metric bolts, they will be black, then just get a bolt that is about 1" longer than stock
probiby less than $5 for the pair.
Old Apr 1, 2003 | 07:14 PM
JSJ EG6's Avatar
Default Re: do i need longer bolts for my Z SPEED tie bar? (euclid)
thanks for the help
Teh Boss
Dec 22, 2012 08:29 PM
SD_EM1
Jun 10, 2004 11:28 PM
Train
May 6, 2004 09:49 PM
civicdohc
Dec 31, 2003 06:55 PM
BolivianDc2
Sep 28, 2003 07:03 PM
