Speedometer doesn't work
Old Mar 31, 2003 | 07:58 PM
CarreraGT2E's Avatar
Default Speedometer dosnt work
Hi, I guot a speedometer question. On my 94 honda accord Ive been driving around not knowing how fast Im going for about the past year. Ive been doing good with it till johnny lawn pulled me over and gave me a ticket and wouldnt buy the fact that my spedometer didnt work. My plan is to pleed not guitly due to Mechanical Error and say it just happend that day.Anyhow I do know theres something faulty with the spedometer itself because we tested the speed sensor drirectly out of the transaxle using a snap-on diagonostic computer and that reads the speed. The speedometer just dosnt work. MY tach works fine though. along with everything else on the guage cluster , minus, the speedometer.
My speedo stays on 20 when I drive, goes back to zero when I turn the car off.
Once in a while the speedometer does work though. Id say out of every full tank of gas itll read for 30 or so miles. Some times the speedo will kinda of bounce too.
Ive checked for loose wires and any other connections and so far have found none.
I have yet to take the dash apart and look at the speedometer.
Hopefully someone can help out with some advice before I just end up going to a speedometer service place. By the way I was quoted between 100-400$ to get it fixed so Id rather not do that. I still owe bank because I broke my last tranny thinking I was cool baking the tires all the time. Im doing my best to not do dumb things anymore.
Anyhow thanks for any help.
-Eric
In case anyone cares, my cars a 94 lx sedan, carbon fiber hood, tein s techs. Im trying to go for the jdm look. Thats it for now cause none of the good jobs hire under 18. 2 months though and I can bring in the cash.
Old Mar 31, 2003 | 10:43 PM
ldodol's Avatar
Default Re: Speedometer dosnt work (CarreraGT2E)
do you have indiglos? could be rubbing up on those.
Old Apr 1, 2003 | 04:29 AM
greensleeper's Avatar
not sure what he problem but if everything is solid up to the guage cluster then it's probably timew to break into it.
best of luck with the mechanical failure crap. you;d better be able to prove it did not work. and that you have fixed it. 9/10 they won't buy it even with that.
Old Apr 1, 2003 | 04:59 AM
CapnChunk's Avatar
I had the same thing happen in my car - every now and then it would click on and start working and then drop back to 20. Mine also bounced around from 5 to 15 when I was pulling up to a stop sign.
It's time to replace your cluster. I picked up mine from a junk yard for $175. All it needed was a little cleaning. You might be able to get just the speedometer - but most likely they'll say you need the whole thing. I would also say to take out all of your bulbs and swap them in if you know they work. I had to take it out once it was installed because a few were burned out.
It's pretty easy to do it yourself. It's like 12 screws holding the dash together and 4 screws holding in the cluster. I did it in an hour, but I'm also easily distracted.
Old Apr 1, 2003 | 07:31 PM
Next time I find time or it gets warm I guess Ill take the thing out and take a look at it. Else its off to the junk yard. Ive seen some on ebay tfor 75$
no I dont have indiglos on there, its all stock guages
So you guys think Id be better off with just pleeding guilty for the speeding ticket? I dont know how much Im looking forward to the points but o well thats life.
Thanks
Eric
Old Apr 5, 2003 | 11:54 PM
akabigboi25's Avatar
my 91 accord speedometer did the same and it was the VSS (vehicle speed sensor). maby u can try that if u haven found the prob...
Old Apr 6, 2003 | 12:17 AM
Old Skool's Avatar
Default Re: Speedometer dosnt work (akabigboi25)
is it plugged in?
Old Apr 7, 2003 | 10:24 PM
Default Re: Speedometer dosnt work (Old Skool)
haha, haha.
jxhxb
Dec 29, 2007 08:58 PM
watacanga
Nov 29, 2007 08:47 AM
Neophryte
Feb 14, 2005 05:02 AM
SpoolinEK
Dec 11, 2003 03:42 PM
