1" master cylinder swap
Old Mar 31, 2003 | 07:02 PM
DavidG's Avatar
Default 1" master cylinder swap
Is it possible to mount a booster/MC from a GSR or ITR into a 4th gen? I know a 90 Civic Sedan MC or 90 Integra booster/MC will fit but Im trying to find a 1" MC upgrade.
Thanks,
Old Mar 31, 2003 | 07:31 PM
Shawn C's Avatar
In The Garage
Default Re: 1" master cylinder swap (DavidG)
you will hate yourself if you ever attempt this. the lines (only 1 i think) is on the wrong side, and it would be a good idea, too, to use like an Si or GSR booster, which is a tight fit.
Old Mar 31, 2003 | 07:33 PM
FourthGenHatch's Avatar
Just get a 90-91 EX Sedan 15/16 ones, almost 1'' but so much easier to put in.
Old Mar 31, 2003 | 08:32 PM
Ben Ogle's Avatar
Default Re: 1" master cylinder swap (FourthGenHatch)
I used a 93 teg (w/ ABS) MC/booster and the fitting was kind of a pain but it works. With the stock front brakes the pedal is super stiff. It was less stiff (and more likely to lock em up with crap tires) with the teg front brakes on.
Ben
[Modified by Ben Ogle, 5:34 AM 4/1/2003]
Old Mar 31, 2003 | 10:32 PM
Eggman's Avatar
If you want to use the 1" MC from a DC, you'll need the booster and then you'll have to re-bend one of your lines (location depends on which year MC).
If you want to use the 1" MC from a DA (ALB) like Ben said, you'll need the booster and then reflare one of your lines.
If you want to ues the 15/16" MC from a 88-91 Prelude?/86-89 Accord?/90-91 Civic EX? then you just need the MC and barely bend one of your lines a tiny bit.
Old Mar 31, 2003 | 11:03 PM
CRX7's Avatar
Default Re: 1" master cylinder swap (Eggman)
90-91 Integra 4 door = stock line location, but need the integra booster
90 Civic EX 4 door = stock line location, use your current booster
Old Apr 1, 2003 | 05:45 PM
DavidG's Avatar
Default Re: 1" master cylinder swap (CRX7)
I think Im gonna try getting a LS/GS abs booster/MC to get the car ready for bigger brakes.
It has a teg 15/16" one in already but Im gonna transfer that into my road Civic. Actually, I tried removing the 15/16" booster/MC tonight but got stopped by the end-most flare nut which was rounding off, even with the flare nut wrench I bought. Since that one needs to be reflared anyway, can I just cut that line or will it be to short when I need to reflare/reconnect it?
Thanks guys.
Old Apr 1, 2003 | 06:05 PM
kickz's Avatar
howcome if you were using the 1inch from itr you have to change the booster too ?
it doesnt fit ??
Old Apr 1, 2003 | 07:53 PM
Eggman's Avatar
Default Re: 1" master cylinder swap (kickz)
Although they both are a two bolt pattern, the bolt pattern is different.
Old Apr 1, 2003 | 09:02 PM
Adam F's Avatar
what are you doing it for?
[Modified by Proelite103, 12:03 AM 4/2/2003]
Old Apr 1, 2003 | 09:45 PM
91vtecripper's Avatar
Default Re: 1" master cylinder swap (Proelite103)
so it dosent matter if the master cylinder or booster is abs or not
Old Apr 2, 2003 | 03:26 PM
Ben Ogle's Avatar
G2 teg ABS (LS/GS/GSR) MC's are all 1", the non ABS ones are 15/16.
Ben
Old Apr 2, 2003 | 08:18 PM
DavidG's Avatar
Default Re: 1" master cylinder swap (Ben Ogle)
Proelite,
It is for my CRX which I use for lapping etc. Getting ready for some bigger brakes.
I just transferred the 15/16" teg booster/MC I had in the rex to my road Civic tonight. All done except I couldnt bleed the left rear wheel as the 14 year old 8mm bleeder screw is rounded. Pedeal feels firm enough though so Im gonna see if I can get a new bleeder screw and put a vice grip to that old one.
llantaguy
Jul 13, 2007 12:29 AM
DANG YO
Sep 27, 2003 04:35 PM
rasta420
Dec 3, 2002 12:37 PM
RedlineUBRF
29
Sep 18, 2002 07:32 AM
JeffS
Mar 7, 2002 08:22 AM
